Old 10-17-2017, 01:58 PM   #1
zombkilla420
zombkilla420 is on a distinguished road
Default Compatible parts between gens?
I currently have an 02 SL2 with a bad rod bearing, so I bought a 91 SC as a cheap replacement. Are any parts compatible? I don't want to get rid of my sl2 but I don't have the time or money to fix it, and can't find anything online. Thanks in advance
Add to zombkilla420's Reputation
Rate the quality of this post and help zombkilla420 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zombkilla420 is offline   Reply With Quote
Old 10-17-2017, 02:10 PM   #2
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default Re: Compatible parts between gens?
Eek..
You would be hard pressed to find any parts that are compatible between 1st and 3rd Gen cars- even from the standpoint of going from a Sport Coupe (SC) to an SL (Sedan)...
The SOHC engines are different from the DOHC engines... not only from a standpoint of HP- but the gear ratios were different as well...as well as the PCM are different too...
You *may* be able to do some swapping with modifications if you are just doing engine pieces... Just my thoughts.
http://www.differentracing.com/tech_..._diagrams.html
Gen 1= 91-94/95
Gen 2= 95-99
Gen 3= 00-02
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 10-17-2017, 02:36 PM   #3
alordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud of
Seats? (but not seatbelts/holder bolted on) . . . and wheels. Maybe manual trans. Probably a few miscellaneous sensors
'91 was the first production model year, and a lot changed.
The 1991 and 1992 SC had the DOHC engine; there was no SOHC coupe available.
In 1993, Saturn introduced the SC1 with SOHC engine and renamed the SC to SC2.
Some engine parts may swap over, but the early cars did not have a top mount so the timing cover would be different.
We have a swap guide. . . it's a lot of reading
http://www.saturnfans.com/forums/showthread.php?t=88699
Old 10-25-2017, 10:07 AM   #4
Rednekrich
Rednekrich is on a distinguished road
Rednekrich's Avatar
1993 SC1
2000 SL2
probably would have been cheaper to get a ring and bearing kit, I don't know why you would pull that out of a donor car? but I will for sure say its hard to mix and match. we converted a 93 sc1 to a 2000 sc2, that required a whole lot of fabrication, and had to pull harness, everything on the engine and ACE then relocate battery because of where the ECU mounts our 93 brake master cylinder is in the way of the ecu mount. no we actually have the freedom to do that on our race car. but we noted that the 98 we bought as a second donor to the project really didn't have much to offer, most parts had some little difference that made it unusable. so pretty much wasted 200 dollars. barely made our money back on parts because we were able to use the struts and some suspension parts.
but we completely tore down and rehabbed the motor to include a ring, seal and bearing kit. and that was pretty cheap to have all new seals and gaskets and crank bearings.
Add to Rednekrich's Reputation
Rate the quality of this post and help Rednekrich reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rednekrich is offline   Reply With Quote
Old 10-25-2017, 08:54 PM   #5
Macgyver
Macgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of light
You bought the absolute worst year for compatibility you could for owning an 02 and buying a 91.
Add to Macgyver's Reputation
1st Gens cgg17 S-Series General 11 06-02-2017 08:41 AM
Where Have All the First Gens Gone? blackbeard S-Series General 46 02-28-2014 03:35 PM
Compatible Parts proveniebam S-Series Tech 4 09-16-2013 06:20 PM
Looking to learn about compatible parts from other model years nbkyqks S-Series General 2 04-25-2010 12:16 PM
1st & 2nd gens post your pics of 1st & 2nd gens saturncrzy S-Series General 9 06-13-2008 08:33 AM
