Old 10-16-2017, 01:36 PM   #1
lukesloane
lukesloane is on a distinguished road
Default 09 Vue sunroof drain hose outlet
Hello everyone,
I have an 09 Vue that has a leaking sunroof drain hose on the driver side somewhere below the dashboard. Water is pooling inside a void space behind an electrical connnector of some sort inside the body on the left side. When I pour water into the sunroof drain, nothing comes out the bottom and this void space fills....then drains slowly onto my floorboard. Everything is dry from the sunroof to the dash, and I zip-tied the hose to the drain on the sunroof to make sure. I also snaked a weed whacker line down the hose and it kept feeding through, so I know it's clear....just not sure where it is coming out.
Does anyone know how/where the drain tube exits the vehicle and how to access it? I put an inspection mirror inside the void space but can't see where the hose leads.
Thanks!
Add to lukesloane's Reputation
Rate the quality of this post and help lukesloane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lukesloane is offline   Reply With Quote
Old 10-18-2017, 06:28 AM   #2
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default Re: 09 Vue sunroof drain hose outlet
Was hoping somebody would post a diagram for you from the Vue service manual which I sadly don't own. Perhaps stop by a local autoparts store and look it up if you can find a Haynes manual for the Vue/Equinox on the shelf.
In lieu of that, don't know why your weed wacker line down the sun roof drain tube wouldn't expose the exit point within the vehicle...if say you have a breach under the instrument panel. You say the line is clear, therefore why doesn't the weed wacker line exit the drain tube which not only shows 0 blockage but also where the drain tube ends and where the line exits the drain tube?
Add to gm7's Reputation
Rate the quality of this post and help gm7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gm7 is offline   Reply With Quote
Sunroof drain hose observations 2004 Ion Logan Savage Ion Tech 7 07-19-2015 02:59 PM
Radiator Surge Tank Outlet Hose/Pipe P/N needed. marginal Aura General 4 08-29-2013 05:27 PM
SC clean SR drain hose, with sunroof closed? k1hog S-Series Tech 1 08-22-2009 10:34 AM
Transmission drain plug outlet stripping out Saturn_ol'timer S-Series Tech 7 07-04-2008 12:31 AM
Sunroof drain hose gunny S-Series Tech 2 02-12-2002 05:41 PM
