Old 10-14-2017, 09:12 PM   #1
GWalker
GWalker is on a distinguished road
Default Won't idle
I cleaned battery cables and check fuses. Now it won't idle at low rpm. I thought it might be computer resetting but I've drive it 15-20 miles. Guess I should have left it alone...
Add to GWalker's Reputation
Rate the quality of this post and help GWalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GWalker is offline   Reply With Quote
Old 10-15-2017, 11:34 AM   #2
Default Re: Won't idle
What's it idling at now? Model, year, engine, mileage?
Old 10-15-2017, 01:26 PM   #3
GWalker
2006 Vue 167k 4 cyl I took battery cables off and let set for 15 min. It idled good for 5 min then drove it a couple of miles stopped and let idle for a few more minutes turned in driveway and died again...
Old 10-15-2017, 01:49 PM   #4
What is idle rpm (200, 400, 600, 800, 1200)? At 167k miles, what maintenance was done, parts replaced? Throttle ever cleaned, spark plugs replaced?
Old 10-16-2017, 07:15 PM   #5
GWalker
I think I found the problem. Throttle body needed cleaning. Now getting the heat and air solved. When I turn on the fan my windshield wipers comes on no heat or air. Checked all fuses. Any Idea????
Surging idle in park and when started, flux idle in drive terminal89 S-Series Tech 2 06-07-2017 08:19 AM
04 2.2 5spd rough idle, stumbling, squeeking and rattling sound at idle tsdfab Vue Tech 2 06-04-2015 04:23 PM
Rough IDLE/Low IDLE no check engine light savage21 Vue Tech 9 12-08-2010 12:27 AM
Iacv fixed high idle now getting periodic low idle cmpcpro S-Series Tech 1 07-28-2010 09:18 PM
idle idle idle idle idle idle (dead) nocolourblue S-Series Tech 23 12-29-2006 02:08 PM
