Old 10-14-2017, 03:14 PM   #1
Calcamonk
Calcamonk is on a distinguished road
Default 2003 Saturn Ion 2 2.2 liter 5 speed
AC Heater control panel fan not working.
Ac fan was blowing cold air at all settings day b4 yesterday. Went to store and parked, as always turned ac and recirculation buttons off then turned fan off. Got back in car and stared the car as normal, turned ac on and recirc turned fan knon to 4 and nothing happend. Checked fuses, all seemed ok. Then started car again and the radiator cooling fan came on as ac did. Took that as a good sign. I am thinking it's the ac heater control panel is out again but just not sure. Any help would be great.
Add to Calcamonk's Reputation
Rate the quality of this post and help Calcamonk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Calcamonk is offline   Reply With Quote
Old 10-15-2017, 11:31 AM   #2
Default Re: 2003 Saturn Ion 2 2.2 liter 5 speed
With or without ac on, try all blower speeds. The first three speeds have power going thru a resistor card. High speed is a direct connection to battery.
Old 10-22-2017, 11:00 AM   #3
Calcamonk
Fan does not work at all. Just as mentioned in the post. All 4 speeds do not work, whether ac is on or not. Thinking it is the blower motor it self. Reason being is that I can turn the account on and turn fan knob to any setting and the recirculation light comes on. But no fan
Old 10-22-2017, 11:09 AM   #4
Are you a heavy ac user living in the South or hot states requiring more ac use than northern states? If you think the blower is worn or broken, you can try disconnecting it and wiring it directly to battery power and see if it runs. Do you have a cabin air filter? Some are unaware of cabin filter use and discover a blocked filter.
Old 10-27-2017, 02:03 PM   #5
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
Are you familiar with using a multimeter?
BACKGROUND
The light for the heater control (fan) is on a separate wire than the power (out) to the blower motor. One can be on with the other not working.
All power for the lights for the heater control are run through one separate connector on the back of the heater control. All power for all the actual function are run through the other (IIRC).
Testing the controls could help.
Using the multimeter you could check the resistance change across the leads for the fan motor dial. You should see the resistance value change for each position of the dial. If it doesn't, the controls are bad.
You don't even need to strip the wires back, just poke the pointy tip of you meter lead through the insulation (there are MUCH better ways of doing this however) and check that way.
Peter in Lansing MI
current cars:
94 SW2 (White, automatic)
99 SL2 (Silver Plum, manual)
99 SL2 (Dark Blue, manual)
04 Ion 3 (Berry Red, 2.0L automatic)
07 Ion 3 (Cypress Green, 2.4L, manual)
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
2003 Saturn Ion Blower Speed Issue captbics Ion Tech 17 08-14-2016 12:51 AM
2003 Saturn VUE - 5 speed - What is a fair price? skijay Vue General 16 05-11-2009 12:02 PM
ATF Specification: 3 liter Vue AF33 5-Speed AndyH Vue General 2 01-06-2005 02:41 PM
Drove a 2.2 Liter 4 speed auto VUE at work the other night. OhioVueBoy Vue General 12 11-28-2004 08:00 PM
2003 Saturn Vue AWD V6 (5 speed auto trans leaking) fredrick Vue General 22 09-02-2003 09:16 PM
