Old 10-11-2017, 05:26 PM   #1
cycodude
cycodude is on a distinguished road
2002 SC1
Dizzy Transmission fluid disappearing?
My ex bought this car for my son in June. Starting about 2 weeks ago, he began noticing issues with the transmission either not shifting at all or shifting very hard. He also noticed that it was low on fluid. It keeps losing about a quart every day or two. It's right at a quart each time as 1 quart fills it perfectly according to the dipstick. The big issue is that I cannot find a leak anywhere. This leads me to believe that it's only happening when he is driving and stops when he parks. There's no sign of the fluid in the coolant that we can see. So the question is: Where is the fluid going and how do we fix this!?! Thank you for your time
Add to cycodude's Reputation
Rate the quality of this post and help cycodude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cycodude is offline   Reply With Quote
Old 10-11-2017, 06:34 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Transmission fluid disappearing?
All saturn s series models have an external spin-on transmission filter.
On your car, it may not be on tight and spewing while driving.
It is located under the air snorkel, on the drivers side, just in front of the battery area.
It is mounted horizontally and should be changed at least every 30,000 miles or more often if there are issues
Old 10-11-2017, 06:43 PM   #3
billr
Put some fluorescent dye in the fluid and check for leak areas with a UV light.
Add to billr's Reputation
Old 10-12-2017, 08:45 AM   #4
TXSaturn02
TXSaturn02's Avatar
The filter for the automatic transmission needs to be put on TIGHT. It is not the same as the oil filter. People have a tendency to use the same pressure to tighten as the oil filter, which is not enough, causing leaks while under pressure (driving). Check this first, then look for leaks elsewhere.
New owner As of 01/01/18: 225,000 Miles
As of 06/15/18: 49,365 Miles
Old 10-14-2017, 06:29 AM   #5
bumpdraft
bumpdraft's Avatar
1998 SW2
If you were driving a 2-cycle dirt bike, the problem would be a leaking crankshaft seal on the transmission side.
I once lost two quarts of engine oil in the driveway by forgetting to reinstall the drain plug. The puddle was not hard to find. Iím not the only one. Within a few weeks of my mistake, there was someone here at Saturnfns that said they liked to flush out the old oil with two quarts of fresh.
(Bump)
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Small transmission fluid leak from radiator transmission cooler line EvanVanVan S-Series Tech 5 10-13-2014 06:55 PM
2000 LS 4 cylinder power steering fluid disappearing karsung L-Series Tech 7 09-03-2013 09:40 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 05:57 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
Transmission Fluid flow from Transmission into the radiator ? Luke S-Series Tech 5 11-10-2005 10:52 AM
