Old 10-13-2017, 12:20 PM   #21
pierrot
pierrot's Avatar
Default Re: Electric Wrenches
Originally Posted by toggenburg View Post
I see you use TCW3 in the gas tank, me too.
Increases my mileage ~7% more by adding like 2oz oil with 10 gallons of fuel.
I'm curious, toggenburg: while you had the LW200 did you use this TCW3 in it as well? If so, was there any improvement inf fuel economy? If you didn't use it in the LW, why did you chose not to?
287,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 10-13-2017, 02:28 PM   #22
Diamond193
Diamond193 is on a distinguished road
Originally Posted by NWSaturn247 View Post
TCW3 is a Marine rated 2 cycle oil. It scavenges all the junk and moisture out of the system and burns clean. I have gallons of Pennzoil Marine Premium Plus Synthetic Blend 2-cycle oil I purchased from the O'Reilly clearance, some for only $3.47 a gallon, yes gallon.
So I just add it to my gas on a fill up ?
Add to Diamond193's Reputation
Rate the quality of this post and help Diamond193 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diamond193 is offline   Reply With Quote
Old 10-13-2017, 02:48 PM   #23
NWSaturn247
NWSaturn247 will become famous soon enough
NWSaturn247's Avatar
1993 SL2
I have been adding TCW3 rated 2 cycle oil to the gas since Fall 2012. My emission tests in 2013, 2015 & 2017 were dramatically lower than previous tests.
I think most just fill up and add the 2 cycle oil later. The standard optimum ratio is 640:1 or 1 ounce per 5 gallons of fuel. If you purchase the Supertech gallon at Wal-Mart it works out to ~20 cents a dose for a 10 gallon fill-up. Get a Stabil container that portions out the ounces or get a Dollar Tree baby bottle to measure out the oil.
Here is the thread that started it all
http://www.ls1.com/forums/f48/been-t...06/index1.html
1993 SL2 AT - 187k miles
running blend of various SOPUS oils & MGL3614
TCW3 dosed fuel
Goldie: a dame to kill for...watch out squirrels!
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 10-13-2017, 03:07 PM   #24
RedRocketZ28
RedRocketZ28 is on a distinguished road
That's some good info. I may start giving that a try as well.
Add to RedRocketZ28's Reputation
Rate the quality of this post and help RedRocketZ28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedRocketZ28 is offline   Reply With Quote
Old 10-13-2017, 03:10 PM   #25
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Well Pierrot,
The LW was my wife's car and whether I did consistently add the TCW3 I just recall; the reason being that the car as in the driveway while our house burnt to the ground last year & alot of it's panels melted in the heat.
That level of stress has kinda blocked out some normal recall about that car.
Old 11-07-2017, 09:25 PM   #26
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
The pump said 10% ethanol. How do they know there is not ethanol in the gas?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-08-2017, 10:34 AM   #27
If the pump label does not match the claim and/or price then just test it for alcohol. Simple to do. Kits are at the local general aviation airport.
Impact wreches,recomended? davidt321 S-Series General 32 11-22-2011 01:07 AM
S-car as electric car? Dante S-Series Mods 59 09-14-2008 08:49 PM
Electric 94 SL!!!! ajs_saturn S-Series General 5 02-18-2008 02:34 PM
An electric SC2 cdp326 S-Series General 12 06-12-2005 04:47 PM
Electric SC2 clemsonsaturn S-Series General 2 03-30-2005 10:44 PM
