Old 10-11-2017, 04:46 PM   #1
NWSaturn247
NWSaturn247 is on a distinguished road
NWSaturn247's Avatar
1993 SL2
Default Electric Wrenches
Recommendations/links for wand type electric wrenches appreciated.
Would have come in handy when I replaced my serpentine belt. I was going to replace the tensioner but could not with the tools at hand. Tight quarters.
Fortunately, only replacing the junk serpentine belt that Lee Automotive used with a Goodyear Gatorback belt solved the chatter problem. I can use the Goodyear Gatorback tensioner on my next (3rd gen) Saturn.
1993 SL2 AT - 185k miles
running blend of various SOPUS oils & D3422
TCW3 dosed fuel
Goldie: a dame to kill for...watch out squirrels!
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 10-11-2017, 05:02 PM   #2
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Default Re: Electric Wrenches
Wand type?
I have never seen them.
Handheld electric impact wrench is all I am familiar with.
But, because of the impact wrench body, I don't believe it can be of much use on anything under the hood.... cannot get a good straight bead on bolts.
Old 10-12-2017, 06:59 AM   #3
toggenburg
toggenburg's Avatar
I see you use TCW3 in the gas tank, me too.
Increases my mileage ~7% more by adding like 2oz oil with 10 gallons of fuel.
Old 10-12-2017, 07:57 AM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
https://www.google.com/search?tbm=is...t9B70airy43vM:
^From Milwaukee^
Like toggenburg said, is there enough clearance to use it?
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 10-12-2017, 08:39 AM   #5
No. These sorta work: http://www.gearwrench.com/wrenches/g...on-wrench.html
There is a richpin06a video on how to replace the tensioner using conventional hand tools.
Old 10-12-2017, 08:44 AM   #6
The M12 3/8" should fit...but it's too pansy to do most of the bolts (35ft/lbs max).
The M18 3/8" right angle impact driver should also fit and between "mode 2" of 60ft/lbs and the impacts it should be able to take the bolts off fine. Also has a higher RPM of well over 250 so it won't take hours to remove fasteners like the M12 version.
I've never had a problem with hand tools, bit tricky getting a ratchet and short socket in there but slip the jack handle over the ratchet handle and everything comes off fine.
Old 10-12-2017, 09:05 AM   #7
serenitythen
serenitythen has a spectacular aura aboutserenitythen has a spectacular aura aboutserenitythen has a spectacular aura about
We're you trying to replace the tensioner from up top (under the hood)?
Or did you have the passenger wheel and splash guards removed and were approaching it from inside the tire well?
Add to serenitythen's Reputation
Rate the quality of this post and help serenitythen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
serenitythen is offline   Reply With Quote
Old 10-12-2017, 10:17 AM   #8
Many tools will fit and break the bolt loose but when the bolt is almost out you will fine that the tool is jammed up against the midrail.
Try this: https://www.youtube.com/watch?v=Or0-0oG5Hsc
Old 10-12-2017, 11:49 AM   #9
2NDSOUT
2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough
2NDSOUT's Avatar
1999 SL
Here is a thought, based on top of Richpin's video and also from my mechanic friend who was a Saturn Mechanic for 20 years...
Another option on removing anything from the side of the engine is to remove the Upper Motor Mount while supporting the Oil Pan with a small thin block of wood. Gradually you will hike the engine up, via the Oil Pan; while removing the Upper Motor Mount at the same time. You can get an extra 4-6 inches of clearance with the top back of the engine against the firewall.
I've done this numerous times over the past 20 years without any issues or damage to any top engine pieces when I have needed to get to things on the Passenger side of the engine.
For what its worth in helping out to remove worn out parts.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 10-12-2017, 11:59 AM   #10
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by OldNuc View Post
Many tools will fit and break the bolt loose but when the bolt is almost out you will fine that the tool is jammed up against the midrail...
As Exactly Man would say, “exactly!”
The designers were given clearances and they used them all.
I found shapely / refined Snap On wrenches give more clearance than relatively clobby, break-proof Craftsmans.
Old 10-12-2017, 12:31 PM   #11
bumpdraft
bumpdraft's Avatar
1998 SW2
Slack the Tensioner
Old 10-12-2017, 01:39 PM   #12
The problem is those Snap-On wrenches are expensive. There are Asian produced decent copies of the 6 point angle head wrenches.
The engine can be positioned relatively easily to allow using a 3/8" drive impact wrench to pull both bolts. This is not a difficult task actually.
Heat up the wrench and bend it, maintains strength.
Old 10-12-2017, 02:33 PM   #13
NWSaturn247
1993 SL2
Thank you for the replies. My method was to jack the car and remove the splash guard. If I was home at the time I would have had a better selection of tools. I could have proceeded to lower the car and then set it up for motor mount removal but decided if the new Gatorback belt resolved the issue, I would call it good and save the Goodyear Gatorback tensioner (49212) for my next S-series.
I paid less than $11 for the Goodyear serpentine belt, money well spent.
TCW3 dosed fuel
Old 10-13-2017, 06:07 AM   #14
Diamond193
Diamond193 is on a distinguished road
What is this TCW3 ? Any fuel addtives that actually work or anything I can add to a fresh oil change ? Used to use z-max for the oil and gas but stopped buyen it awhile ago
Add to Diamond193's Reputation
Rate the quality of this post and help Diamond193 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diamond193 is offline   Reply With Quote
Old 10-13-2017, 06:56 AM   #15
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
I'd prefer a subtractive rather than an additive. Would be nice to get the ethanol out of the gas. Our last tank gave us 28.6, we seem to be creeping up a half MPG each tank. I wonder what we could get away from the corn belt.
Regarding electric wrenches, I am pretty sure all my wrenches have electrons.
Bryan Cotton
'99 SL2, owned since new
5 speed manual
Add to Waiex191's Reputation
Old 10-13-2017, 07:11 AM   #16
toggenburg
toggenburg's Avatar
https://www.walmart.com/ip/Super-Tec...allon/16795065
Old 10-13-2017, 08:28 AM   #17
NWSaturn247
1993 SL2
TCW3 is a Marine rated 2 cycle oil. It scavenges all the junk and moisture out of the system and burns clean. I have gallons of Pennzoil Marine Premium Plus Synthetic Blend 2-cycle oil I purchased from the O'Reilly clearance, some for only $3.47 a gallon, yes gallon.
TCW3 dosed fuel
Old 10-13-2017, 09:03 AM   #18
Waiex191
Waiex191's Avatar
I think I've got some of that stuff. I burn it in my 1971 Harley Model D gas golf cart. It's a two stroke. The cool thing is the motor runs backwards for reverse. I rebuild the golf cart too.
Bryan Cotton
5 speed manual
Old 10-13-2017, 11:51 AM   #19
There is a place in Poplar Grove
https://www.pure-gas.org/index.jsp?stateprov=IL
Poplar Grove MARATHON Octane 90
J & D Countryside 815-765-3729 13615 Hwy 76
Old 10-13-2017, 12:04 PM   #20
Waiex191
Waiex191's Avatar
Cool! Will get the next tank there.
Bryan Cotton
5 speed manual
Impact wreches,recomended? davidt321 S-Series General 32 11-22-2011 01:07 AM
S-car as electric car? Dante S-Series Mods 59 09-14-2008 08:49 PM
Electric 94 SL!!!! ajs_saturn S-Series General 5 02-18-2008 02:34 PM
An electric SC2 cdp326 S-Series General 12 06-12-2005 04:47 PM
Electric SC2 clemsonsaturn S-Series General 2 03-30-2005 10:44 PM
