Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 10-11-2017, 02:10 PM   #1
Somders
Somders is on a distinguished road
2004 VUE Red Line
Default 04' Redline front end vibration
Guys, have an annoying vibration in the front end while driving on interstate 60-80 mph range in my 04' Redline fwd. Has a clunking sound to it that is felt in the steering wheel. Where can I start to determine what it is? Car had it when I bought it used but chalked it up to worn out tires that needed replaced. I drove it for a few months and finally bit the bullet and bought new tires. Also had the shop do full alignment before installing the new tires. However vibration/clunk is still there. Where can I start to determine what it is? Any help is greatly appreciated. Thanks.
Add to Somders's Reputation
Rate the quality of this post and help Somders reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Somders is offline   Reply With Quote
Old 02-07-2018, 09:34 PM   #2
blaster88
blaster88 is on a distinguished road
2004 VUE Red Line
Default Re: 04' Redline front end vibration
I can't post links yet - go to youtbe search for Saturn vue clunk noise.
Maybe that?
Add to blaster88's Reputation
Rate the quality of this post and help blaster88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blaster88 is offline   Reply With Quote
Old 02-08-2018, 07:36 AM   #3
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
Bad front bearings. very common problem.
Mine developed a kind of a buzzing vibration sound / feel. I replaced both sides. The old left side was probably ok, but the bearing from the passenger side definitely was causing the buzzing vibration.
I bought the new bearings on Amazon, $32 each (mine doesn't have anti-skid)
You may be able to jack / lift one wheel at a time, make sure to block it, then run the engine to spin the wheel as see if you get the vibration.
Add to waiter21's Reputation
Old 02-09-2018, 08:03 AM   #4
atikovi
Check swaybar bushings and end links, tie rod ends, struts and strut mounts, ball joints and control arm bushings.
Add to atikovi's Reputation
Old 02-13-2018, 06:08 AM   #5
Lovemyredline
Lovemyredline is on a distinguished road
2004 VUE 3.5L
2001 SC1
Type “Saturn Vue clunk noise” in YouTube search (Salvador Estrada) and see if it helps, worked on mine. Also check lower control arm bushings, mine were shot and were not difficult to replace. Agree with previous post to look at sway bar bushings and links.
Kevin
Add to Lovemyredline's Reputation
Rate the quality of this post and help Lovemyredline reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lovemyredline is offline   Reply With Quote
'02 SL2 Front end vibration luvme2tymes S-Series Tech 8 06-13-2009 06:12 AM
2004 Redline Tranny Vibration noise chadster Vue General 3 04-02-2007 09:20 AM
Front end vibration Westwind S-Series Tech 2 12-28-2006 08:05 AM
Vibration at 50MPH '06 Redline grandpastock Vue Red Line 3 03-16-2006 09:21 PM
ls front end vibration lewis L-Series Tech 3 04-27-2001 02:27 PM
