Old 10-10-2017, 10:52 PM   #1
Wrldtrvlr01
Wrldtrvlr01 is on a distinguished road
Default WTB SATURN timing cover 1.9 dohc 1996.
My timing cover is cracked and am looking for another one.
Add to Wrldtrvlr01's Reputation
Rate the quality of this post and help Wrldtrvlr01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wrldtrvlr01 is offline   Reply With Quote
Old 10-11-2017, 06:43 AM   #2
Highmile
Highmile's Avatar
Default Re: WTB SATURN timing cover 1.9 dohc 1996.
might help if we knew what for....
Highmile
'95 SL1 641k and counting
Add to Highmile's Reputation
Old 10-11-2017, 08:11 AM   #3
cgg17
cgg17 is on a distinguished road
cgg17's Avatar
Highmile
Title says 1.9 DOHC 1996... Unless that was edited in after your comment..
On the cover, I would try local U Pull It yards or Pick N Pulls. Maybe also call around to normal junk yards and see if anybody has one.
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-11-2017, 09:10 AM   #4
'92-'98 timing covers swap, '91's are all screwed up and '99+ are too narrow for the '91-'98 head. GM also says the SOHC & DOHC timing covers swap (valve covers won't swap that way).
Old 10-11-2017, 09:26 AM   #5
pierrot
pierrot's Avatar
I agree with cgg17's post above. A wrecking yard, whether it's a traditional one or "pick and pull" for yourself, is your least expensive and most likely source for finding the timing cover. If you're not likely to go and pull your own part, and you need more options for availability, you might consider using the website below for wrecking yards nearby and across the country (even outside of the country). I've used businesses in Michigan and Kansas, or Missouri - I can't quite recall between these two states - so they'll ship parts to wherever you are with the additional cost.
http://www.car-part.com/
(Plug in the necessary information.)
One GM OE parts website claims availability for a new timing cover (although I suspect an inaccuracy there).
https://www.gmpartscenter.net/auto-p...ine-parts-scat
Item no. 12 on the schematic and price list.
287,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 10-11-2017, 10:16 AM   #6
I'd suggest a '98 cover, if you can find one. For sure, '98 has the extra port in the oil pump cover that gives extra oil to the timing chain. I'm pretty sure, but not 100%, that '97 also had this port but '96 and earlier did not..
+1 on pulling the cover yourself. That way, you can get spare bolts for free. No matter how careful you are (I used Ziploc bags, another put them in a magnetic tray), those buggers have a way of escaping and it's usually the center bolts, not the outer ones
Looking for Saturn timing cover. 1.9 dohc 1996 Wrldtrvlr01 Classifieds 1 10-11-2017 07:28 AM
98 dohc timing cover spyderem1 L-Series Tech 1 03-13-2012 09:03 AM
1996 sl1 timing chain cover removel ? ASAP onefstbird S-Series General 7 10-02-2005 06:59 PM
WTB:DOHC Timing Cover blackeagle1 Classifieds 7 05-16-2005 02:08 PM
Color Change 1996 DOHC valve cover Saturnspeed Classifieds 1 11-06-2001 08:53 AM
