Old 10-09-2017, 04:04 PM   #1
Ohio_Mike
Ohio_Mike is on a distinguished road
Default Blower motor for HVAC not working
I have a 2002 L200 with manual HVAC control unit. 254,000 miles.
Over the past month I have noticed the air speed fluctuating as I am driving. Yesterday the blower didn't work at all after I started the car. I messed with the controls, and... nothing. It finally came on after 10 minutes. And when it came on, it worked normally, and the speed control worked normally.
Today I started the car, and the exact same thing occurred.
Thinking there could be a bad electrical connection in the speed control selector switch and/or associated wiring, I removed the HVAC control unit and performed an inspection. Everything looked fine.
So does this mean the blower motor is the culprit? Could it be the resistor pack?
Some pics I took of the HVAC control unit:
dropbox.com/s/17dcpg9v01ia1du/1.jpg?dl=0
dropbox.com/s/5yjjrqbhjhw4ovu/2.jpg?dl=0
dropbox.com/s/vtxek5glv5ju269/3.jpg?dl=0
Thanks
Add to Ohio_Mike's Reputation
Rate the quality of this post and help Ohio_Mike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ohio_Mike is offline   Reply With Quote
Old 10-09-2017, 06:03 PM   #2
Default Re: Blower motor for HVAC not working
A very attractive TV mom scolds her adult son about his hair, declaring "Don't do dat!? I think its funny because of her Spanish accent that adds humor to the moment. Obviously from the disassembled hvac control head, you found nothing out of the ordinary and shouldn't have to disassemble it as you did. Hopefully you can put Humpty Dumpty back together again and move on.
I'm guessing several possibilities; main power or ground wiring (burned, discolored from worn connections), worn blower motor or faulty resistor card. From the service manual; The blower motor resistor card is located on the right side of the HVAC module forward of the re-circulation actuator. The resistors located on the card lower the blower motor voltage to create the Low, M1, and M2 speeds. The resistor card has a fusible link which if blown, will require that the card be replaced.
The blower motor will still operate in High when the fusible link is blown.
The operation of the A/C and heating system is controlled by the buttons, rotary switch, and knobs on the HVAC control head. The compressor clutch, rear defog and recirc motor are controlled electrically by push buttons on the control head.
Blower speeds are controlled in all modes by a 5 position rotary switch. The blower motor and compressor are not operational when the blower switch is in the OFF position.
The temperature knob controls the temperature door through a cable from the HVAC control assembly to the HVAC module. The mode knob controls the various mode positions using an actuator located on the HVAC module.
The control head logic will automatically select outside air and A/C whenever defrost and heater/defrost is selected, regardless of the A/C and recirculation button position.
Old 10-09-2017, 07:12 PM   #3
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Ohio Mike, The next time the blower misbehaves try this:
Get a long pencil, paint stick or similar. Remove the cabin air filter cover and filter. Turn the ignition switch on. Put the blower on low. Very quickly with one of above mentioned tools, spin the fan and see if it runs. Must do this very quickly. Damage to fan blade is possible if you are too slow. Be careful.
I have a similar situation as you. I suspect there is a dead spot on my fan motor. Moving the fan allows it to run perfectly. Have done this several times on one of my L's.
Let us know what you find.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 10-15-2017, 04:19 PM   #4
Ohio_Mike
I removed the blower motor. Brushes are fine, but the commutator was worn down. I find this fascinating, as the brushes are supposed to be sacrificial. Either the brushes are too hard or the commutator is too soft. But I'm not complaining, as it worked for 254K miles.
Here are some pics:
www.dropbox.com/s/1pci2t7g4bwbn4s/4.jpg?dl=0
www.dropbox.com/s/2gdp32iw2ryqgi3/5.jpg?dl=0
www.dropbox.com/s/rrt5uwt3fq75cdr/6.jpg?dl=0
Old 10-15-2017, 04:20 PM   #5
Ohio_Mike
Oh, and the cabin filter was disgusting. I think it's original.
Old 10-15-2017, 04:23 PM   #6
Ohio_Mike
N/a..........
Old 10-15-2017, 04:25 PM   #7
Ohio_Mike
N/a....
Old 10-15-2017, 04:28 PM   #8
Ohio_Mike
Nn/aa...
Old 10-15-2017, 04:30 PM   #9
02 LW300
02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about
02 LW300's Avatar
2002 L-Series 2.2L Sedan
We believe you, just keep posting! I see commutator wear rather brush wear as a common blower motor failure cause. Also fuel pumps have the same failure issue.
2002 L200/5 loaded, loving my stick shift car finally on the road!
2002 L200 grandson's car now
2002 LW300 sold.
Add to 02 LW300's Reputation
Old 10-15-2017, 06:57 PM   #10
At 254k miles, a well worn blower motor. What can't be determined from pictures is whether the worn brushes and commutator are so worn the brushes no longer make good (spring loaded) contact to allow electrical connections to run the motor. If brushes have enough 'meat' left, maybe the commutator can be machined down to remove the two lips for a flat surface to allow brushes better contact to extend its life? Machining as in rotor chucked into a drill press and spun while a flat file refinishes commutator to a like new flatness. If this is possible, scraping in between commutator segments will prevent short circuiting one set of windings from the next. Just sayin'......
You can also wire this reassembled blower and see if it still runs or replace it with a used one.
Old 11-08-2017, 01:02 PM   #11
PaulGraz
PaulGraz has a spectacular aura aboutPaulGraz has a spectacular aura about
PaulGraz's Avatar
2001 L-Series 2.2L Wagon
I've got a similar problem. Only mine didn't fluctuate at all, just died completely. One day all speeds worked fine, the next day nothing at any fan speed.
I checked the 40 amp fuse under the hood, it's fine.
I did notice that if I turn on the AC, the amber might lights up - until I turn the fan switch to off. Am I assuming too much by thinking that proves the fan speed switch is OK?
I'm going to try the "pencil" trick right now. Thanks for the pics and diagrams, they should help.
I've got a spare HVAC control unit, as I've already messed with that a few times and replaced the fan switch about 3 times over my 250K miles...
~Paul
2001 LW200 (4th saturn owned) 255K+ Miles!
71 Volvo 1800E, 73 Volvo 1800ES, 08 Volvo C30, 11 Volvo V50
Gone on to other owners: 92 SL2, 95 SW2, 96 SC2
Add to PaulGraz's Reputation
Rate the quality of this post and help PaulGraz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PaulGraz is offline   Reply With Quote
Old 11-08-2017, 01:25 PM   #12
PaulGraz
PaulGraz's Avatar
Tried it - did nothing. :-( The fan moved freely though, I guess that's a good sign.
~Paul
Old 11-08-2017, 03:23 PM   #13
Your situation seems similar to the op, very high mileage and worn out blower motor. Since we haven't heard from the op with a visible worn blower motor, the only way to determine whether or not its a blower failure is to try the easy things first if you have a spare control head. If the same results occur, dead blower, replace the blower.
Old 11-08-2017, 08:45 PM   #14
PaulGraz
PaulGraz's Avatar
Pretty much what I was thinking - I ran out of time and daylight today. I'll try again on Saturday.
Can the blower motor be replaced through the cabin air filter opening?
~Paul
Old 11-08-2017, 11:04 PM   #15
In one word, yes but you'll have to remove more pieces before access to the blower motor is made. According to service manuals, the entire windshield cowling is removed with wipers removed then cowling and wiper xmission. Then the blower can be removed for replacement. Examine your cabin air filter and immediate area to see how extensive disassembly will be before jumping on this project. You may as well order the blower first once you determine the blower is worn out and have time set aside for this repair.
Old 11-14-2017, 11:03 AM   #16
rb6667
rb6667's Avatar
I can send you a very detailed PDF file on replacing the blower motor when you are ready to tackle this project. Just send me a PM with your email address. It's too large to post here on the forum
Glad to help.
Old 11-17-2017, 10:03 AM   #17
PaulGraz
PaulGraz's Avatar
Glad to help.
PM sent.
If you want, I could put the PDF up on my personal web space, and provide a link in the thread here for others to download.
~Paul
Old 11-19-2017, 02:22 PM   #18
rb6667
rb6667's Avatar
PM sent.
PDF file sent to you. If you can post on your web site so others can download, please do so.
Thanks for handling this.
HVAC Blower Motor Stopped Working Havok10 Aura General 11 08-02-2015 02:06 PM
HVAC Blower motor not working Madness10 S-Series Tech 7 06-23-2013 08:46 PM
2003 Vue HVAC blower motor jccbei Vue Tech 8 08-13-2012 04:57 PM
Hvac blower motor P.DADDY S-Series Tech 6 01-22-2009 08:02 PM
HVAC Blower Motor Dying...can one fix motor? flyhop S-Series Tech 2 09-28-2006 09:08 PM
