Old 10-08-2017, 06:52 PM   #1
eureb
eureb is on a distinguished road
Default Coolant Leak - 2004 Saturn L300
My wife has a 2004 Saturn L300-2, and we've noticed a coolant leak on the driver's side of the motor. The uppermost part of the motor that is wet with coolant is where the hose that's at the bottom of the reservoir tank meets the engine block. I originally thought it was the thermostat, but from googling, the thermostat only has one hose coming off of it, and this part has 3 (one going to the radiator, one to the reservoir and one to the back of the motor... the heater core?)
Any ideas on what that part is and what could be leaking? Thanks!
Note: The water pump had a slight leak as well, so we replaced that already, this other leak is more severe and on the opposite side of the motor.
Add to eureb's Reputation
Rate the quality of this post and help eureb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eureb is offline   Reply With Quote
Old 10-08-2017, 07:50 PM   #2
Dsaturn
Dsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the rough
2001 L-Series 2.2L Sedan
Default Re: Coolant Leak - 2004 Saturn L300
Welcome to the show.
Best way to find a coolant leak is a pressure test. Search This board and you will find tons of info on how to do a test.
Add to Dsaturn's Reputation
Rate the quality of this post and help Dsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dsaturn is online now   Reply With Quote
Old 10-08-2017, 09:36 PM   #3
02 LW300
02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about
02 LW300's Avatar
2002 L-Series 2.2L Sedan
image.jpgthis is called the engine block fitting. There is either an o-ring or gasket between this part and the block.
2002 L200/5 loaded, loving my stick shift car finally on the road!
2002 L200 grandson's car now
2002 LW300 sold.
Add to 02 LW300's Reputation
Old 10-08-2017, 10:32 PM   #4
eureb
Originally Posted by 02 LW300 View Post
Attachment 51546this is called the engine block fitting. There is either an o-ring or gasket between this part and the block.
Yes! That's the part! That's where the wetness looks like it starts. I'll have to see if I can find the part numbers for the fitting and the gasket/o-ring to track those down...
Thanks!
Old 10-13-2017, 09:44 AM   #5
Russet
2002 L-Series 3.0L Sedan
Now that you found the problem - you might want to ask did you change the Thermostat as well? This is the other part others forget as it is buried under the intake runner. If your Saturn has not had this change this would be a fix that should be done as well. Those hoses and gasket should be readily available at your local auto repair parts store or if your not able a shop should be able to do this for you. So when was the last time the belt was changed and thermostat and hoses changed?
Add to Russet's Reputation
2004 Saturn L300 V6 - low coolant light stays on patrickwigingto L-Series Tech 7 07-11-2017 10:21 AM
2003 - Saturn L300 - Coolant Leak solved floridasl22002 L-Series General 2 09-19-2016 08:28 AM
2000 Saturn L300 massive coolant leak chad h L-Series Tech 15 03-29-2014 08:19 PM
Engine coolant leak 2002 L300 BigDaddyGuns L-Series Tech 3 11-14-2011 09:42 AM
2004 Saturn L300-coolant/chk engine SATURNCHIC L-Series Tech 4 09-13-2011 08:58 AM
