Old 10-06-2017, 02:51 PM   #1
tvwbug
tvwbug is on a distinguished road
Default Help Transmission Problem After Crash
ok my 2004 Vue 3.5 AWD was hit pretty hard while parked. I fixed the frame and replaced all the broken parts in the front end. It looks brand new again. so I took it for a test ride and it almost immediately shifted into a higher gear very harshly, and no other gears after that. Seems like it goes to 2nd or 3rd gear. when I stop the same thing happens as soon as I start out again. I've been searching the forums trying to find an answer. there are not any check engine lights of any kind illuminated. The car has always performed flawlessly as far as shifting is concerned. Any ideas?
Add to tvwbug's Reputation
Rate the quality of this post and help tvwbug reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tvwbug is offline   Reply With Quote
Old 10-06-2017, 04:59 PM   #2
atikovi
Default Re: Help Transmission Problem After Crash
No check engine light doesn't mean there isn't any codes stored in the tcm or pcm. First thing to do is get it scanned.
Add to atikovi's Reputation
Old 10-06-2017, 07:45 PM   #3
tvwbug
I have a code scanner from Hrbor Freight, that shows no codes stored or pending
Old 10-06-2017, 07:58 PM   #4
atikovi
You need a code scanner more sophisticated than a simple OBD2 scanner to get transmission related codes.
Old 10-07-2017, 05:39 PM   #5
tvwbug
so it seems it is the neutral safety switch, mine is the ten blade flat style. does anyone have info on adjustment or replacement instructions? or a good source to get the switch as well as the connector (mine is damaged from the crash)?
Old 10-12-2017, 01:56 PM   #6
tvwbug
Does anyone have a used switch or a source for one, apparently they are not available GM part # 24228212.
Old 10-12-2017, 02:30 PM   #7
atikovi
Self service junk yard would be the first place to check.
Transmission problem.... would like to try and fix myself cash S-Series General 4 11-03-2009 04:54 PM
Acceleration problem...gets stuck...possibly transmission? Or a gas problem? Dingo Warrior S-Series General 34 03-29-2009 12:20 PM
94 Transmission problem omahadave S-Series Tech 4 01-24-2006 03:06 PM
Re: 96 SL1 Transmission Problem .... pasha S-Series General 3 12-13-2005 08:22 PM
Front end problem cause crash? Mark Jericho Vue General 66 11-09-2004 05:31 PM
