Old 10-10-2017, 10:28 AM   #61
Default Re: no start urgent
Originally Posted by Melissa_M View Post
So that previous battery connection was good enough to make the panel light, but when I engaged the starter , it was not enough to energize it. I would have expected to still get panel lights after that, tho. If it was good enough to light the panel once, why not twice? Did it just use up all the juice that could be drawn thru the connection?
sososo glad you guys told me to check the cable.
Put the neg batt cable on again today (i left it off overnite). Rechecked the pos cable - no wiggle, but I got 2 more turns with my 1/4"wratchet. Then a rough start (why?). Then died.
Then started. And again!.......
Ignore the starter wiring. Those wires are fine and you're distracted by doubts about starter wiring. Your problem is main power and wiring - battery or battery cables.
Is your battery a top or side terminal battery? Side terminals are easily damaged from over tightening and can strip out the few threads on soft leaded posts.
Old 10-10-2017, 11:31 AM   #62
Melissa_M
Melissa_M is on a distinguished road
I do have a side terminal battery.
yes, I realize the fact my new starter works verifies the purple wire. I wanted to familiarize myself with the process for future needs.
Because I am just guessing another no start is in my future, and of course the starter will need replacement sometime. Plus, I have another vehicle that will be needing a starter.
I tried to daisy-chain some of the harbor freight dvm wires together and tested on a spare computer battery I have. Not surprisingly, 2 HF meters do not agree with each other on the value, though. IF there was an issue with the purple wire, could I take any value except 0 as a good sign?
1999 SL2 MANUAL ~76K
Add to Melissa_M's Reputation
Rate the quality of this post and help Melissa_M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Melissa_M is offline   Reply With Quote
Old 10-10-2017, 12:04 PM   #63
Waiex191
Waiex191 will become famous soon enoughWaiex191 will become famous soon enough
Waiex191's Avatar
It is a good sign as long as it is 12-ish.
Bryan Cotton
'99 SL2, owned since new
5 speed manual
Add to Waiex191's Reputation
Old 10-10-2017, 12:49 PM   #64
If you measure the small purple wire for voltage, you'll see battery voltage only when the ignition switch is turned to the START position. A simple alligator clip/red probe onto this terminal and the negative probe of the meter is connected to any part of the engine block or chassis. Turning on ignition won't show 12 volts. Only when the ignition switch is turned to START position will you see battery voltage and you'll hear the starter running. When you see 12 volts at START, the starting circuit is fine. When you hear the starter run and turn over the engine, the starter is fine.
Is everything all right now?
Old 10-10-2017, 01:32 PM   #65
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Melissa,
Glad you were able to persevere and follow through to find the solution to your no-start.
Just think of all you have experienced AND learned in the last few days.
-Push starting a stick transmission.
-Using a DMV
- How to safely get under then remove and install a starter while on ramps.
-To learn 'how tight is tight" when working with battery connections (keep them as tight as possible, especially with cold weather coming soon....they tend to contract somewhat and can loosen up a bit.)
AND
-That you can trust many Saturnfans members to reach out to you and provide tips on what to check for and to ask you many, many questions (even at all hours of the day or night).
Congrats!
Old 10-10-2017, 01:43 PM   #66
Melissa_M
thanks for indulging me.
I've started the car several times, so that part is good, anyway.
Still not confident my connections at the starter terminals will last the test of time. I know I used the socket to tighten the nuts but might not have had a wrench on it. Too much torque and I risk damaging it.
Same with the battery cables, but at least those are easier to get to.
toggenburg, you are so right, I was thinking the same thing. I just wish it wasn't all so difficult for me.
Old 10-10-2017, 02:13 PM   #67
Waiex191
Waiex191's Avatar
Well done!
Bryan Cotton
5 speed manual
Old 10-20-2017, 07:39 PM   #68
Melissa_M
re: starters from DB electrical
have you guys used their starters for other vehicles, as well?
Old 10-20-2017, 08:47 PM   #69
Yes, works fine.
urgent. car turns over but won't start Jesse Pinkman S-Series Tech 4 03-13-2015 09:12 AM
How Urgent is TPS replacement? SlowRide S-Series Tech 22 02-07-2012 06:28 PM
URGENT: Old Nuc I need help! Joe S S-Series Tech 17 04-21-2011 08:56 PM
2002 SL2 random no start, urgent. LowMileSC1 S-Series Tech 6 11-26-2010 12:49 AM
Urgent Girafro S-Series Tech 8 12-06-2004 12:43 PM
