Old 10-05-2017, 06:39 PM   #1
627
627 is on a distinguished road
Default 2004 L300 audio wiring
I've got a 2004 L300 that's in great shape and can probably last me another several years, but I'm itching to swap out the factory head unit with one that does Bluetooth.
My only problem is that this is one of the models with the advanced audio package with the factory amp and for whatever reason I can't find a definitive answer as to whether I can just use a normal harness or if there's any different harness or a bypass or other special wiring concerns I need to be aware of to make the thing work. I'd like to assume that since I haven't seen any straight answers I'm able to get the normal harness and be just fine, but measure twice, cut once, etc.
Can anyone confirm this for me? I've provided model numbers for the aftermarket parts I'm looking at below if that's any help.
Harness that seems to be right at least for the base model: Metra 70-2002
Aftermarket head unit: Pioneer MVH-X370BT
Add to 627's Reputation
Rate the quality of this post and help 627 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
627 is offline   Reply With Quote
Old 10-05-2017, 07:01 PM   #2
soulsurvives
soulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to all
2002 L-Series 2.2L Sedan
Default Re: 2004 L300 audio wiring
I put an Alpine with Bluetooth in my wife's L300 and it works great. She has the premium stereo and on star. If I remember correctly I got whatever free harness that came with the stereo as I got it from Crutchfield. Don't forget to hook up the factory amp turn on wire, I didn't at first and thought I was in trouble LOL.
Add to soulsurvives's Reputation
Rate the quality of this post and help soulsurvives reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
soulsurvives is offline   Reply With Quote
Old 10-05-2017, 11:46 PM   #3
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
In 2002 the premium sound system used a piggyback amp system. The plugs are the same and you can use the amp or disconnect and just use the base wiring.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 10-06-2017, 09:23 PM   #4
627
Thanks for the quick response, guys! Glad to hear this should be reasonably painless.
Is that one of the normal wires in this setup? Was it just not a good connection at first or something?
Old 10-07-2017, 01:00 PM   #5
soulsurvives
I don't really remember. I wired the radio to the harness while I was in the house and when. I installed it in the car I got no sound. I then remembered that the car had a factory amp so I then hooked up the sure needed and I was good to go.
Old 10-13-2017, 10:49 AM   #6
Russet
2002 L-Series 3.0L Sedan
Did you ask Pioneering audio support to ask what other steps or connections to use? They could also provide more sources to your question as well.
Add to Russet's Reputation
Audio Gone! Need wiring schematic / help minjaz Aura General 4 04-03-2012 10:45 PM
03 Advanced Audio Wiring Diagram? Solareklypz Vue Tech 0 04-09-2008 02:24 PM
Advanced Audio System wiring..... DOMESTIC_Disturbance General Saturn Discussion 13 11-05-2004 03:31 PM
Wiring configuration in Adv Audio Amp benpatient General Saturn Discussion 0 03-07-2003 08:33 PM
Aftermarket Audio Wiring Slidder Miscellaneous Tech 5 03-05-2000 08:39 PM
