Old 10-07-2017, 05:12 PM   #21
Kaspar7
Kaspar7 has a spectacular aura aboutKaspar7 has a spectacular aura aboutKaspar7 has a spectacular aura about
1999 SW1
Default Re: 19999 SW1 temp gauge behaving oddly after radiator replacement
Originally Posted by Waiex191 View Post
For me it was fill, drive, cool down, repeat. Took 3 or 4 times and now it's good.
Thanks! That's exactly what I was doing! I thought there might be something else but I guess that's it!
Add to Kaspar7's Reputation
Rate the quality of this post and help Kaspar7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaspar7 is offline   Reply With Quote
Old 10-07-2017, 05:22 PM   #22
Kaspar7
1999 SW1
Originally Posted by 2NDSOUT View Post
The Water Pump is located on the Passenger Side of the Engine- about midway.
If you take off the Passenger Wheel, and the Splash Guard immediately behind the Wheel, you will see the Main Camshaft Pulley. Look just up and North East of the Camshaft Pulley and you will see the Water Pump Pulley.
Internet Picture for Reference (This engine is NOT my engine):
Thanks for the great pic and the description of how to see the pump. I read that there were 3 10mm bolts on the pulley and 6 on the pump. I peeked in just the right direction and sway where it is. I'd have to use your directions to reach it if it needs to be replaced.
So far, I've got the fan motor replaced and tested. It comes on instantly when you switch the A/C on. It also turns on when the coolant temperature hits 210F. Yeah, should be 226F but there's room for variations in the car and in thermometers. I had tried the test Richpin mentions in his video, disconnecting the electrical connector from the ECTS to make the fan come on - and it didn't come on! So, the long route of warming up the motor, checking the coolant temp with a thermometer and watching the fan.
Now, the temp gauges reads ~1/2 most of the time. The fan kicks in when the gauge reaches ~5/8 and off again when it gets back to 1/2. Looks like I'm done with the engine cooling - and cabin heating - for now as both seem good. Next up, clean the throttle body, replace its gasket, and replace valve cover gasket!
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 09:07 PM
Wierd Saturn L200 Gas Gauge/ Temp Gauge and change oil light probs! Crittercage L-Series General 1 09-09-2016 01:23 PM
This is oddly hot. XRL Vue Mods 5 07-04-2009 02:21 AM
Temp Gauge Dead, ECTS Replacement? DecayingOmega S-Series Tech 5 05-19-2007 11:24 AM
New Engine and radiator.. Temp gauge input needed!!!! sideout303 S-Series Tech 5 11-26-2003 12:41 AM
