Old 10-03-2017, 08:38 PM   #1
GMCya
GMCya is on a distinguished road
Default Power Window Power Door locks Diagnosis
Hi guys, I'm a new Saturn owner here. Looking for some advice.
It seems the power windows are starting to work intermittently on my 2008 Aura 2.4L XE. I've read a few of the different posts trying to diagnose what might be happening, but I was wondering if anyone here had some advice for narrowing it down.
A few days ago the driver's side window got stuck half way down after being out running some errands. None of the other master controls for the windows worked. The passenger window control also did not work. Eeekk.
After waiting about 30 minutes, leaving the car parked at home, the driver's and passenger's windows worked immediately upon start up. I quickly put the windows back up thinking they might never go up again.
Over the last few days, a pattern emerges where the passenger's window control button might work most of the time, but the driver's window and rear windows will not respond from the master control or from their own rear controls / buttons.
None of the locking buttons on the inside of the car will respond - they appear to be inoperative.
The two front doors and sometimes the rear passenger door lock can be opened by the key fob, but the rear driver's door is inoperable from any of the fobs or controls.
All doors can lock manually and be opened from the inside.
The power sunroof appears to be working all the time.
Does this sound like a failing door or window actuator? Could it also be a door or window switch? I wouldn't think it was a fuse as fuses are either 'on' (good) or off (broken).
Are there any online resources (paid or free) for diagnosing these types of issues?
Grateful for any clues as to what I should look at first. Already spent $1,200 getting other issues fixed from the dealer, looking to save some labor costs.
Add to GMCya's Reputation
Rate the quality of this post and help GMCya reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GMCya is offline   Reply With Quote
Old 10-03-2017, 09:49 PM   #2
Default Re: Power Window Power Door locks Diagnosis
Where are your door lock switches? Where are the power window switches? If they're on center console or separate, this may point which way to troubleshoot. In general, if switches are grouped together, wiring harnesses are routed where wiring may be the problem. If switches are grouped into the driver's door, wiring is routed thru the hinge area and flexing of harnesses may damage wiring. Ground connections are another consideration. Several grounds are placed around the chassis - studs allow ground connections fro local circuits. Alldata or Mitchell provide online subscription service for service manuals.
Power door locks,power window,fan for heat don't work dddaaa S-Series Tech 1 08-11-2011 11:40 AM
2002 SL1 Driver's Door( with power window & locks ) davemanuel S-Series Tech 0 03-26-2011 03:41 PM
Stuck window and No Power Locks oreoucky S-Series Tech 4 08-22-2010 03:22 PM
power locks and window t0pk0w S-Series Mods 3 07-09-2003 02:06 AM
Power Door Locks Power Drain robert_vue Vue General 7 05-26-2003 08:52 AM
