Old 10-02-2017, 10:33 AM   #1
rowdydog
rowdydog has a spectacular aura aboutrowdydog has a spectacular aura about
rowdydog's Avatar
2005 ION Red Line
Default Redline steering problems, fixed
Okay so I have a 2005 Ion Redline that I had problems with the steering locking up, I changed out the electric motor with a used one thinking that was the problem, turns out that motor was bad and was give me an indicator on my Dash locking up worse. So I put the old one back in I was still having problems when I turned right and was breaking the steering would momentarily locked up, I had a knocking noise when I wiggle the steering wheel back and forth, so one day I had a friend wiggle it so I can see what the problem was. Turns out the rack had play where the tie rod went into the end of it, so I replace the steering rack with a rebuilt one and problem solved. Just a little FYI.
Add to rowdydog's Reputation
Rate the quality of this post and help rowdydog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rowdydog is offline   Reply With Quote
Old 10-04-2017, 08:41 AM   #2
WrightMan
WrightMan is on a distinguished road
2004 ION-2 Sedan
Default Re: Redline steering problems, fixed
Good thing you checked so the tie rod didn't pop off. My wife was parking her Oldsmobile Intrigue and the tie rod just came right out. She said she was stuck and when I got there both tires were aiming at each other. It was pretty weird but at least it happened when she was barely moving the car.
2004 Saturn Ion 2 Black Trim Headlights, Bluetooth Fogs, and Smoked Taillights
2004 Crown Vic Mostly Modified
2000 F150 Off-Road Mostly Stock
2013 Escape 2.0T AWD
Add to WrightMan's Reputation
Rate the quality of this post and help WrightMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WrightMan is offline   Reply With Quote
Fixed steering pump whine RobertGary1 S-Series Tech 7 09-24-2017 11:47 AM
Steering Finally Fixed Mike171979 L-Series General 4 10-04-2006 10:54 AM
93 sc2 problems....fixed Rusty S-Series Tech 0 02-14-2006 03:41 AM
how do i tell if the steering recall was fixed? Alex C S-Series General 2 07-15-2005 06:57 PM
Steering Noise Turning Left Fixed! ricksLS1 General Saturn Discussion 4 12-21-2001 08:04 AM
