Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 09-29-2017, 03:01 AM   #1
scayetanot
scayetanot is on a distinguished road
Default Socket for front wheel bearing
Hi,
I do have a saturn vue 209 hybrid. Anyone know the socket I have to buy to remove the wheel bearing ? there is a big nut which fix the wheel bearing
Thanks
Add to scayetanot's Reputation
Rate the quality of this post and help scayetanot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scayetanot is offline   Reply With Quote
Old 09-29-2017, 06:46 AM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: Socket for front wheel bearing
40 mm
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 10-01-2017, 05:52 PM   #3
scayetanot
Thanks. Are you sure about the 40mm ?
Because most of the socket I found are about 36mm or 38 for some of them.
I have found as well the axle nut has a hexagone of 36mm
Old 10-01-2017, 05:53 PM   #4
scayetanot
As I have only one car, I check websites before starting the replacement and make sure I have the right socket.
Old 10-02-2017, 04:49 PM   #5
rb6667
rb6667's Avatar
I helped a buddy of mine who has a Vue. It was a 40MM. It is possible that the Green line Hybrid might use a different size?
Old 10-24-2017, 01:09 PM   #6
scayetanot
Yes it was a 36mm
Bad Front Axle Bearing (Not wheel bearing) ? cjhsa Vue General 19 08-08-2017 07:56 PM
front wheel bearing Mary's Vue Vue Tech 7 06-09-2017 02:56 PM
Front wheel bearing on 01 SW2 beaverplt S-Series Tech 6 04-05-2011 09:39 PM
Front wheel bearing is bad loworange88 S-Series Tech 2 02-09-2011 06:23 PM
front wheel bearing Thundercat Vue Tech 13 01-07-2010 12:09 PM
