Old 09-26-2017, 09:36 PM   #1
Homerlasvegas
Homerlasvegas is on a distinguished road
Default 2003 Vue with a serious vibration
I first thought the problem was bad tires. I have just bought the vue and replaced the clutch. I'm not sure what the problem is.
It drives great under 55 over 60 it really starts to vibrate. I have had the wheels balanced and rebalanced. At over 65 it begins to feel like the car is about to come unglued.
HELP ??
It almost feels that there is a lopsided wheel..
The Vue has 104,000 miles as of today..
Add to Homerlasvegas's Reputation
Rate the quality of this post and help Homerlasvegas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Homerlasvegas is offline   Reply With Quote
Old 09-27-2017, 07:58 AM   #2
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
Default Re: 2003 Vue with a serious vibration
Raise one front wheel at a time (so only one wheel turns).. Support it under the wheels "A" member so the wheel is close to its normal riding height. Run it in gear to see if you can re-produce the vibration...
Careful - I'm think speedometer will read 1/2 speed if one wheel is turning and the other is not. i.e. the raised wheel will be turning at 60 mph even though the speedo reads 30 mph.
A bent rim would have shown up when the wheels were balanced. However, if the hub was mounted with crap behind it, you could get some runout (wobble). You'll see this if you spin the wheel while its raised.
Possibly bent jackshaft or axle, bad wheel bearing, bad jackshaft idler bearing
IMPORTANT
With 100k miles you may be facing possible timing chain issues. I'd inspect the timing chain tensioner. If its the version 1 or 2 style, I'd consider upgrading it to the version #3.
If you decide to do this, DO NOT just simply switch it out. You will want to inspect the chain and take precautions to ensure the chain doesn't jump timing when you make the switch.
Take a look at this link:
http://www.saturnfans.com/forums/sho...d.php?t=218942
Add to waiter21's Reputation
Old 09-27-2017, 08:16 AM   #3
waiter21
2003 VUE 2.2L
^^ If the brake caliper was mounted on the hub and there was rust buildup or other crap between the caliper and the hub, this could cause run-out problems (wobble). You should see the wheel wobble if you spin the wheel.
Hold a straight edge against the fender so it just touches the tire. Spin the tire slowly . the distance between the straight edge and the tire should be the same (run-out)
Old 09-27-2017, 09:59 AM   #4
Chazberry
Chazberry's Avatar
When this happened on my '03 it turned out to be a bad Brake Hose that didn't let the Caliper release. The dragging Brakes cause heat build-up, warped the Rotor which caused some serious vibration.
Add to Chazberry's Reputation
Old 10-25-2017, 11:29 PM   #5
SL2 Ride
SL2 Ride is on a distinguished road
2005 ION-3 Sedan
+1 for this.
if that is happening, the rim will be hot to touch.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
2003 VUE vibration Rob1956 Vue General 6 05-27-2009 04:29 PM
2003 Vue Steering Vibration jrm1493 Vue General 5 01-10-2009 09:13 AM
2003 VUE AWD w/VTI Vibration SueVue Vue Tech 6 10-13-2005 09:16 AM
Vibration in 2003 Vue AWD V6 DonF Vue General 8 05-27-2003 11:35 AM
2003 L vibration Emanuel L-Series Tech 8 08-28-2002 03:39 PM
