Old 09-25-2017, 07:42 PM   #1
NoDisassemble#5
NoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of lightNoDisassemble#5 is a glorious beacon of light
2004 ION-3 Quad Coupe
Default The O2 sensor on the header
What is it exactly called? I need a new one. It's the sensor that plugs into the exhaust manifold/header.
Add to NoDisassemble#5's Reputation
Rate the quality of this post and help NoDisassemble#5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NoDisassemble#5 is offline   Reply With Quote
Old 09-25-2017, 11:35 PM   #2
Default Re: The O2 sensor on the header
Rockauto and most places list O2 sensors by 'front' for exhaust manifold/pre cat or 'rear'/post cat. Technically, GM uses front sensor descriptions as O2S1 front, O2S2/rear. In V6 engines four sensors are described is relation to which cylinder bank; O2B1S1, O2B1S2, O2B2S1 and O2B2S2. Sophisticated sensor have heaters. Lambda (O2) sensors are also described as wide band sensors.
Stock Header O2 Sensor Conversion Ramics S-Series Mods 25 04-06-2014 08:44 PM
header and o2 sensor jarhead S-Series Tech 1 12-04-2007 11:59 PM
universal o2 sensor for the oem header? xupthree60 S-Series Mods 0 07-27-2007 11:00 AM
O2 sensor fit new header? strongboy2005 S-Series Mods 5 12-05-2006 03:01 PM
94 O2 sensor fits in 91-92 OEM header? SLeepr S-Series Tech 2 12-04-2002 03:23 PM
