Old 09-24-2017, 10:16 PM   #1
BobWolf
BobWolf will become famous soon enough
Default No Camshaft Bearings?
I'm rebuilding the engine in my daughters 07 ION and when I removed the cams I noticed no bearings. Is this common or did someone do a hack job repair?
I also noticed the cams journals and the corresponding cap were slightly gouged. The journals are on the cusp of specs within two or three tenths of a thou of Chiltons specs, the lobes are within 2 thou of each other and in decent shape.
Does anyone have the measurements of the camshaft saddle and cap assembly?
Is there a cam bearing retrofit that is a reliable repair? There are no notches to lock in a bearing. I don't want to junk a working head but also refuse to do a hackassed job. A head swap might be in order.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
Old 09-26-2017, 09:11 AM   #2
Default Re: No Camshaft Bearings?
Presuming all ecotec 2.2L engines are the same, no bearings exist for camshafts. Oil pressure pumped into the oil galleries and clearances allows a thin film of oil to provide lubrication.
'05 camshaft specs;
Camshaft End Play
0.040-0.144 mm/0.0016-0.0057 in
Camshaft Journal Diameter
26.935-26.960 mm/1.0604-1.0614 in
Camshaft Thrust Surface
21.000-21.052 mm/0.8268-0.8252 in
Old 09-27-2017, 11:56 PM   #3
BobWolf
Thanks for the reply, that's what I was thinking too. It kind of makes sense since the cam is rotating mass and doesn't see lateral force like a crank shaft would. I had a GM service manager tell me almost every car manufacturer uses the same design no bearings, I just found it odd.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Camshaft BillyP S-Series Tech 4 05-21-2017 08:24 AM
Front wheel bearings: Ball or Needle bearings ?? Luke S-Series Tech 12 03-26-2011 07:25 PM
How to tell if a camshaft is bad? Growser S-Series Tech 42 02-09-2009 11:16 PM
Camshaft issues come to Vue ski2moro 2008 Vue 13 01-02-2009 10:24 AM
camshaft...engine jgrts20 S-Series General 15 11-15-2005 03:46 PM
