Old 09-23-2017, 07:20 PM   #1
RobertGary1
Default Fixed steering pump whine
I posted about this before but a month ago I changed out my steering lines and pump due to an intermittent leak. Its nearly impossible to determine where fluid spray is coming from so I just replaced it all.
After installing the A1 Cardone pump I immediatly had a whine with RPM and under turning load. Working with tech support I tried pulling 20" of vacuum overnight, turning the wheel off the ground left and right for 15 minutes etc. They eventually determined i had a bad pump and I exchanged it (cost me $6 for RockAuto to do the exchange). I put the second pump in. Same issue. Couldn't find any air in the system but a mind numbingly annoying whine.
So this afternoon I put the old pump back on out of frustration. Magic, its whisper quiet. Time will tell if my leak is still there but I'm happy to have quiet.
On thing i noticed is that the thrust play on the old pump is a fair amount more than the old pump (even without the pulley on). I wonder if the trust is too restrictive on the rebuilts.
So I'll call A1 Cardone Monday and see what they say but it certainly frustrating. Cost me 2 1/2 weekend days and shipping costs to exchange the pump. I'm going to ask if A1 will request the return from RockAuto so they can investigate.
If I do have a leak with the old pump my next pump will be pick and puill.
-Robert
Old 09-23-2017, 11:31 PM   #2
RobertGary1
Default Re: Fixed steering pump whine
It doesn't seem too hard to rebuilt. Has anyone tried that.
-Robert
Old 09-24-2017, 07:40 AM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
Turn One rebuilt the pump for me. It was from a donor car that had 270k on it.
These are some of the same people who manufactured the system in the first place.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 09-24-2017, 07:47 AM   #4
The rotor and blades have to be replaced when these pumps are rebuilt.
Generally in the mass rebuild world all core pumps are disassembled and eyeball sorted for good and failed parts. The bins of supposed good parts then cycle to the assemblers. This process does not produce a high quality pump. What you get is bits from several well used pumps assembled into one repainted unit.
Old 09-24-2017, 08:08 AM   #5
-Robert
The supposed rebuilt pump is assembled from mixed parts, this is what happens as there are manufacturing tolerances and the shaft and rotor may be from different years and even different subcontractors.
Getting a hard goods repair kit is going to be difficult and expensive. The available kits are soft goods only.
Old 09-24-2017, 10:46 AM   #6
RobertGary1
I'm thinking that if my old pump does leak I can disassemble it and just replace the shaft seal. Time will tell if changing the lines fixes the leak. Just fluid sprayed all over so it's hard to tell.
-Robert
Old 09-24-2017, 11:19 AM   #7
RobertGary1
It seems obvious that if you mix parts that have worn on different cars that you'll get differing wear patterns that would result in noise. It must work out on some cars since I've had good luck with A1 Cardone on other applications.
I wonder if these pumps would eventually wear together and stop making noise.
-Robert
Old 09-24-2017, 11:47 AM   #8
I don't think they would ever wear in. Starters, generators, and alternators can be rebuilt this way as you do not have a hand full of critical dimension parts to deal with.
The seal and other soft goods kit is cheap on RA and then you get to do the inspection yourself. If you reverse the blades they are usually good for another 200,000 miles.
New steering pump whine RobertGary1 S-Series Tech 7 09-14-2017 05:47 AM
Low Whine and Steering Wheel Vibration exm22psu Aura General 32 06-20-2009 02:29 PM
power steering whine maybe ? saturnguy2001 S-Series Tech 5 02-07-2008 03:49 PM
Power Steering whine samh61 Outlook General 3 11-11-2007 05:11 PM
Power Steering Whine Gone exm22psu Aura General 14 06-16-2007 06:17 PM
