Old 09-22-2017, 01:02 AM   #1
Mister_Cee
Mister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the rough
Default Seems as if this happened a couple of years ago (coolant level light content)
I know that if the coolant light comes on and stays on, that's not good.
I've also read it the coolant light blinks, then one of a few things could be the culprit:
1) Low coolant
2) Bad/sticking float in the overflow tank
3) Bad/intermittent electrical connector
The dash light in my SW2, however, is neither solidly lit nor is it constantly blinking.
When it does (very infrequently) blink it will do so for about a dozen blinks and then quit on its own. It might recur on another day and it might, like last time, wait a couple of years to do it again.
The last time this happened, I put about 8 ounces of liquid in the overflow tank and that solved the problem for a good length of time.
Opinions on what an intermittent coolant light could mean?
Thanks
Add to Mister_Cee's Reputation
Rate the quality of this post and help Mister_Cee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mister_Cee is offline   Reply With Quote
Old 09-22-2017, 05:42 AM   #2
Signmaster
Default Re: Seems as if this happened a couple of years ago (coolant level light content)
I don't think it's at all uncommon when the coolant level is just a little low. I have experienced the same when I had a nicked drain O-ring on my radiator. If I let the level drop without topping off, it would usually reach a point where the light might flash for a minute or less even as the car warmed up.
I'd just top it off and check the float.
Old 09-22-2017, 10:32 AM   #3
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Six months or so after I got my SC2 I had a similar issue, the coolant light flashing for a minute or two after startup, topping off a marginal amount would turn it off. Happened about once every couple weeks with increasing frequency. What it ended up being was the water pump was weeping just enough to lower the level but not enough for it to visibly drip when parked. Eventually it went completely out and vomited the coolant all over the ground. Later had the same issue with the radiator, although that leak was immediately visible after shining a light on it.
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 09-22-2017, 03:27 PM   #4
Mister_Cee
Thanks for the responses.
This has happened a couple of times over the past 4 years and, each time, I added a very minor amount to the reservoir.
Because it (the sudden and unexpected blinking of the red coolant light) had happened before, I didn't "freak" like the first time I ever saw that light come on. Instead, I anticipated doing what you recommended and, this morning, put a little coolant in the reservoir (whatever a medium sized funnel holds..8 ounces?). The light did not blink during driving around town running today's errands (fingers crossed lol).
Looking on the bright side, I now have a gallon of coolant (minus the 8 ounces or so) if/when it happens again.
When I next see my "Saturn guy" (tough to find someone who knows our cars inside and out and knows their idiosyncrasies, but I found a good one) I'll ask him to take a look for any pin hole leaks that aren't showing up on my driveway.
Old 09-24-2017, 01:49 PM   #5
It's a closed system, so losing coolant means a leak or opening somewhere. In the meantime, rather than 8 oz, I'd fill it up to the MAX line. I outlined it in black Sharpie, so you can clearly see it in the pic here
But you can just use the seam where the top and bottom of the tank meet as a guide. Or right up to the plastic dividers you can see inside the tank
Old 09-29-2017, 01:33 PM   #6
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
Chaos is correct on the divider being a good spot to aim for when topping off, especially when doing it by the light of a gas station canopy at night. I've got a very, very minor leak and I have to do the top-off about once a month. It's not down very far--just enough to trigger the light until I get to the end of my neighborhood and the heat and pressure are building enough for the water to expand a bit.
I know I'll be swapping out a water pump at some point. While not all that difficult and I've done a bunch, I think I'd rather have a colonoscopy than do a water pump swap. However, the colonoscopy won't stop the coolant leak.
Current
1999 SC2 - 435,000 miles
1999 SL2 - 198,000 miles
Previous
1996 SC2 and 1999 SL2
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline   Reply With Quote
Coolant light stays on but coolant is at correct level rke5858 Ion Tech 6 01-21-2017 04:14 PM
Low Coolant Level Light on but Coolant is level when cold Vue Daddy Vue General 0 09-02-2015 11:59 AM
'98 SC2 - High Engine Coolant Temp and Low Coolant Level Warning Light mystic54 S-Series Tech 3 01-17-2013 08:29 PM
03 L300 low coolant level light on intermitently level is fine wooskie L-Series General 16 03-27-2010 04:26 PM
Coolant light and coolant level light flash after gunning it? FightingChance S-Series Tech 7 10-07-2006 10:03 PM
