Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 09-20-2017, 01:14 PM   #1
scayetanot
scayetanot is on a distinguished road
Default Background noise in Vue
Hi,
I do have a Saturn Vue 2009 - 2.4L Hybrid.
I have a background noise coming from the "engine". I am quoting it just give a kind of area from where the sound is coming from.
What I notice is:
- The sound is not there when you start the car
- When in Parking or 'N' and pressing the gas, the sound is not there as well.
- The sound is only there when I am driving.
- The sound seems following the engine frequency
- I can accelerate, shift up/down gear without noticeable issue
- No slippering between shift up/down.
- It's not like a sound made when the engine belt is not tight enough.
- The sound is really following the rpm.
What do you think it can come from ?
No error codes only the C1222
I was following an issue at the transmission level as the sound is not there when I accelerate in Neutral or in Parking.
The car as 198000miles and had an oil change 3000miles ago. Only things notice during an inspection of the car is the engine belt which required to be changed.
I bought the car with 120000miles and I can't be sure about any transmission fluid maintenance before.
What do you think ?
transmission ? engine belt ? something around the wheel ?
Thanks
Add to scayetanot's Reputation
Rate the quality of this post and help scayetanot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scayetanot is offline   Reply With Quote
Old 09-20-2017, 06:04 PM   #2
pierrot
pierrot's Avatar
Default Re: Background noise in Vue
Your description appears to eliminate accessories driven by the crankshaft in some way (water pump, alternator, tensioner pulley, and air conditioner). It would be wise to have someone listen to them with an automotive stethoscope just to be certain they're not generating any unusal or excessive noise noise. It seems to me that your next likely sources are (in no order of importance),
1) front tire tread low, or with irregular wear causing extra road noise to enter the vehicle cabin;
2) the front wheel/hub bearings.
Could the noise emanate from the transmission? Yes, perhaps, but I would consider those other two things first.
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 09-20-2017, 07:02 PM   #3
scayetanot
Interesting because I had a engine code coming up which says that the front right speed sensor is 0.
This is the code : C1222 - Right Front Wheel Speed Sensor Input Signal is 0
Photo Contest - Best Background dummo S-Series General 19 07-12-2016 03:11 PM
new background color? geartooth94 Community Center 1 10-19-2011 02:14 PM
Is that a 1st gen twincam in the background? mattelderca S-Series General 6 12-19-2009 01:42 AM
Background Pics of my Redline for all to use. korax123 Ion Red Line 6 12-31-2004 03:44 PM
Look Closely in the background zallen777 Ion General 5 07-21-2003 11:33 PM
