Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 09-20-2017, 03:48 AM   #1
scayetanot
scayetanot is on a distinguished road
Default ABS Code
Hi,
Could you confirm that C0300 and C1222 are related to ABS or speed sensor.
The code C0300 and P0442 were raised for my saturn vue 2009 Hybrid. I have change the fuel cap and erase the system to clean-up the code.
After having drove for few miles, the engine light was off and come up once more. As I had the C0300 and the ABS/TC light on, I was expecting, finding this code once more but funnily when I have read the computer of the car, the C0300 wasn't there anymore but replaced by C1222.
I don't understand... Anyone already faced these issues?
Regards
Sebastien
Add to scayetanot's Reputation
Rate the quality of this post and help scayetanot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scayetanot is offline   Reply With Quote
Old 09-20-2017, 10:46 AM   #2
Default Re: ABS Code
'C' - chassis codes. What brand of reader did you retrieve codes from?
AutoZone, according to members here, upgraded their readers to decode abs errors. It's presumed the abs light is on all the time to indicate a fault and store codes. If in doubt, always try a another reader to corroborate what you have.
The two error codes do seem to be abs related;
https://www.obd-codes.com/trouble_co...ssis-codes.php
C0300 - Rear Speed Sensor Malfunction
C1222 - Right Front Wheel Speed Sensor Input Signal is 0
Cleared out a code 19 and car runs great...Now I have a code 26 93 SL1 automatic. Pickleperforman S-Series Tech 5 05-01-2014 12:06 AM
SRS Airbag light on B1001 code & code reader ShawnV Vue Tech 11 11-13-2013 07:01 PM
F/S Actron cp9580 code connect scanner/ code reader ShawnV S-Series General 0 06-13-2013 04:25 PM
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 09:26 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 05:17 PM
