Old 09-13-2017, 02:45 PM   #1
bodydoesntrust
bodydoesntrust is on a distinguished road
Default 2003 Ion engine cradle interchangability
Hi. Does anybody know for sure if the engine cradle from an 05-07 Ion or 05-10 Cobalt is compatible with a 2003 (or '04) Ion? Did they change the subframe in some way after 2004? The pictures I've seen online sure do look the same. I'm thinking about taking a stroll out to Pull-A-Part this afternoon to take a close look under some Ion's and Cobalt's and see if I can spot any differences. Thanks in advance. ~Chris
Add to bodydoesntrust's Reputation
Rate the quality of this post and help bodydoesntrust reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bodydoesntrust is offline   Reply With Quote
Old 09-28-2017, 05:08 PM   #2
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
Default Re: 2003 Ion engine cradle interchangability
Do you have any new information for us to report? I am kind of curious.
My previous daily drivers were 99 sl2s and there is tons of information on parts interchangeability out there. On the Ions, I am disappointed by how little there is.
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 10-01-2017, 11:47 AM   #3
BobWolf
BobWolf will become famous soon enough
The ION and Cobalt are the same format and subframes are usually consistent. 2000-2005 should bolt up 2006-2010 to a 2003 should unless GM decided to tweak something.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
Old 10-01-2017, 03:23 PM   #4
pierrot
pierrot's Avatar
A little investigation via OE parts websites shows that the '03 and '04 Ion engine cradle/sub-frame has a differing part number from '05 to '07. The Cobalts from '05 to '07 do share an engine cradle with the Ion.
Ion
'03 - '04 engine cradle: p/n 22611060
'05 - '07 engine cradle: p/n 15918781
My two cents worth: assuming that the part numbers are meaningful, there isn't compatability with the engine cradles between '05 and up Ions or Cobalts with the '03 and '04 Ion. However, the change in part numbers could reflect the deletion of the dreaded CV Transmission and how it would mount within the earlier engine cradle. If there is another transmission which is shared between earlier and later Ions then an engine cradle swap may be possible. (I don't know one way or the other.) Other part numbers should be verified as to whether or not they would fit on to earlier and later model year engine cradles, i.e., engine mounts, engine cradle mounting parts, control arms, steering knuckles, sway bars, etc...
(I only hope that this new member didn't feel himself ignored by the rest of our members as the replies came along time over two weeks after his initial post.)
298,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 10-03-2017, 11:51 PM   #5
col_dude190
col_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura about
2006 VUE Red Line
2004 ION-3 Quad Coupe
I would say it's a safe bet that if your vehicle has a manual transmission, you can more than likely use a subframe from any year ION or Cobalt. Throughout the ION's run, as well as the Cobalt's run, only the Getrag F23 5 speed manual was mated to the 2.2 Ecotec. So regardless of the year, the subframes should be setup for mounting for the manual.
If you're vehicle has either the Aisin 5 speed auto (sedan's or swapped coupes), or the CVT, you will probably want to confirm that all of the mount points for those transmissions are present and in the same positions on the '05 and later subframes. The front mounts in particular for the Aisin 5 speed auto and the CVT are substantially different from the front transmission mounts used on the '05 and later vehicles with the 4 speed Hydromatic auto. The rear mounts appear to be consistent between all of the transmissions used in the ION/Cobalt, but the fronts are pretty different.
All other parts including control arms, sway bars, knuckles, etc. are all swappable between all Delta platform cars (ION, Cobalt, G5, HHR) of all years, so you shouldn't have any suspension fitment issues.
Add to col_dude190's Reputation
Rate the quality of this post and help col_dude190 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_dude190 is offline   Reply With Quote
saturn L100 engine cradle interchangability jimmybpei L-Series General 2 07-19-2012 07:03 AM
Is this engine cradle gone? tgferg67global S-Series Tech 10 04-11-2011 10:39 PM
92 SL2 Engine cradle help! mile2885 S-Series Tech 5 02-02-2007 06:31 PM
engine interchangability jk3006 S-Series General 1 12-29-2005 10:10 PM
Engine interchangability in the S series D114 S-Series General 1 01-19-2004 05:07 AM
