Old 09-12-2017, 02:26 PM   #1
Jax_1995_SL1
Jax_1995_SL1 will become famous soon enough
Jax_1995_SL1's Avatar
Default 1996 SL2 which Wix Fuel Filter Part#
My '96 SL2 is still equipped with its factory installed OEM fuel filter. I changed out the one on my 1995 SL1 using WIX part#33575 (this was several years back in 2012...). When glancing between my '95 SL1 and '96 SL2, the parts look 100% identical, but for some reason RockAuto does not list Wix Fuel Filter #33575 as compatible with my 1996 SL2. Can anyone verify what the correct Wix brand fuel filter part number is for a 1996 Saturn SL2? Thank you!
Also, I remember having a heck of a time getting the fuel line to properly disconnect (shrader valve?). Is there a specific tool or method? I'm embarassed to say that I man-handled this on my SL1, and while the old filter/line did come off... it wasn't pretty..
1995 Saturn SL1 SOHC 5 Speed
Add to Jax_1995_SL1's Reputation
Rate the quality of this post and help Jax_1995_SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jax_1995_SL1 is offline   Reply With Quote
Old 09-12-2017, 02:34 PM   #2
Default Re: 1996 SL2 which Wix Fuel Filter Part#
You might be interested in doing this DIYguy fuel filter mod, then not worrying about it in the future
http://www.saturnfans.com/forums/sho...d.php?t=159814
FWIW, AFAIK, same fuel filter for '95-97. Oreilly's shows MicroGard - Fuel Filter Part # 33575 for my '97 SC2, and the same part number usually means that it's a Wix filter boxed and sold under another name.
Rockauto is only showing generic (Dorman) inline filters for my '97 when I search by going down the left "tree" for parts, but if you do a part search by number, it shows Wix #33575 as compatible for 95-97 S series per attached screen grab
Parts Master fuel filter vs Wix fuel filter AprilSL1 S-Series Tech 21 08-05-2014 08:43 PM
What's the part number for wix fuel filter 98SatSl2 S-Series General 3 06-22-2014 09:39 PM
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 11:34 AM
Fuel Filter Part # gunner S-Series Tech 0 01-23-2005 05:28 PM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 09:14 PM
