Old 09-12-2017, 05:30 AM   #1
Ohio_Mike
Ohio_Mike is on a distinguished road
Default 2002 L200 burning oil
2002 L200 with 2.2 liter engine.
It currently has 252,000 miles on it. It's been using more and more oil over the past 5 years. I am now having to add 1 quart a week.
I'm in Ohio, so on cold mornings I will warm up the car in the driveway. Blueish smoke is emits from the exhaust after it idles for a few minutes. The smoke is very noticeable if it sits there and idles 5 to 10 minutes. The smoke mostly goes away when the car is warmed up and driven.
Worn rings? Valve guide seals? PVC valve?
With this many miles, is it even worth fixing?
Thanks
Add to Ohio_Mike's Reputation
Rate the quality of this post and help Ohio_Mike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ohio_Mike is offline   Reply With Quote
Old 09-12-2017, 08:44 AM   #2
Russet
2002 L-Series 3.0L Sedan
Default Re: 2002 L200 burning oil
Thanks
With situation you should take it in to a trusted shop to verify if the problem is bad or fixable. We on here can't do that for you here.
Add to Russet's Reputation
Old 09-12-2017, 10:09 AM   #3
pierrot
pierrot's Avatar
It currently has 252,000 miles on it. It's been using more and more oil over the past 5 years. I am now having to add 1 quart a week...
...Worn rings? Valve guide seals? PVC valve?
Thanks
With regard to a bad PCV valve, there should be a build up of oil within the air cleaner snorkel and perhaps even at the throttle body if it has gone bad. If the PCV valve is not at fault then, of course, the excessive oil consumption could be caused by either of the other two items you've referred to, or perhaps worn valve guides. The only way to determine which of the two have gone bad is to tear down the engine. You could just make a guess and simply replace the valve stem seals. There is no guarantee, however, that such a repair would solve your problem.
So based on the vehicle's age and mileage is it worth fixing? Relative to the car's value, probably not. Unless you expect to do an engine swap or a rebuild as a DIYer, the cost of such a repair comes close to, or exceeds, the value of the car. This is the sad reality for we owners of older cars. Repair costs start to get too close to their resale value. I am facing this type of concern right now with some repairs. We all have to determine what makes the most sense to us depending on our various financial circumstances and needs.
288,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 09-12-2017, 07:55 PM   #4
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
[QUOTE=Ohio_Mike;2254338
With this many miles, is it even worth fixing ?Thanks[/QUOTE]
^^^ That depends on your situation as Pierrot pointed out. What kind of condition is the body and interior in? Transmission? Give us some ideas about what other parts have been replaced or other repairs.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 09-12-2017, 10:59 PM   #5
02 LW300
02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about
02 LW300's Avatar
2002 L-Series 2.2L Sedan
I work on my own cars so everything is different for me. I am a pack rat so when I choose a car I am in for the long haul. I have only sold one Saturn LW300. All the rest have been L200s, my current driver is the one I will keep for many years. I have parted out 2 and have a third parts car now. I paid $100.00 for a 2003 rollover with 200k miles on it. The engine runs great and uses no oil, I put it in my 02 L200/5 speed loaded driver. I rebuilt another 02 L200 and gave it to a grandson.
2002 L200/5 loaded, loving my stick shift car finally on the road!
2002 L200 automatic, happy new owner
2002 LW300 sold.
Add to 02 LW300's Reputation
BCM likely going bad on 2002 L200 - anybody try to fix one? Xenophile L-Series Tech 4 09-12-2016 06:35 PM
2002 Saturn sl1 standard burning gas bethythecat L-Series Tech 1 04-26-2015 07:45 AM
2002 SL1 stalling and burning lot of oil cdg010 S-Series Tech 14 01-06-2013 09:40 PM
2002 Saturn SC1 smoke and burning plastic smell? whatshizname S-Series General 6 06-09-2010 07:28 PM
oil burning 2002 L300 kenglover3 L-Series General 9 04-10-2003 10:54 AM
