Old 09-11-2017, 09:46 PM   #1
Biz
Biz is on a distinguished road
Default 02 VUE Vacuum line needs home
Hi folks,
I just picked up an 02 Vue 6cyl AWD with a few issues for cheap.
One of these issues is a rough idle. I think I found the root cause of the shaky engine when I see some vacuum hoses dangling. I located 2 of the hoses from the IMRC to both of the VVT variable valve timing modules. What I haven't found is where the input line goes that supplies the IMRC.
I"m including a picture (found it online) pointing to the line that needs to go home.
There are some small green arrows pointing at the line in question.
Perhaps a kind soul out there has one of these jewels and knows what direction to point me to.
Add to Biz's Reputation
Rate the quality of this post and help Biz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Biz is offline   Reply With Quote
Old 06-09-2018, 11:17 AM   #2
Surrender
Surrender is on a distinguished road
Default Re: 02 VUE Vacuum line needs home
Just did valve cover gaskets and spark plugs on the wife's Vue ('03 V6 AWD), but I was also left wondering if this came disconnected from something? Unless I don't understand how it works, I imagine it needs a vacuum source that I couldn't find.
Add to Surrender's Reputation
Rate the quality of this post and help Surrender reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Surrender is offline   Reply With Quote
Old 06-09-2018, 01:27 PM   #3
My L300 uses vacuum to control the intake manifold runner control valve from a vacuum line going to a vacuum manifold by the rear of the engine. A small black plastic box and another tube connects to the intake manifold. Mine use blue hard plastic (nylon?) lines.
Old 06-09-2018, 02:00 PM   #4
Correction - the IMRC is an electric solenoid controlled valve operated by the ecm. The valve provides vacuum to open and close ports to short and long intake runners.
Old 06-10-2018, 10:24 AM   #5
Surrender
In the OP's picture, this hose is connecting to the IMRC valve, but is a very short hose. Are you saying you have something on yours that connects to this hose?
Old 06-10-2018, 02:55 PM   #6
^ If you are asking me a question, my IMRC solenoid valve has an electrical connection to the ecm and vacuum connection, via small diameter blue nylon line to a rear top engine mounted vacuum supply reservoir. A vacuum tap is on the rear of my intake runner to supply vacuum to this reservoir when the engine's running. The lines are clearly in view. I do not know how Vues are setup so I would recommend a member with the same engine examine his for comment. Biz, perhaps you can revisit the junk yard for other Vues to examine IMRC setup too or wait for member replies.
Old 06-21-2018, 04:49 PM   #7
spenser4
spenser4 is on a distinguished road
I'll look at my vue and let u know route and try to get u a picture.
Add to spenser4's Reputation
Rate the quality of this post and help spenser4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spenser4 is offline   Reply With Quote
Small vacuum line under TB...where does it go? flyhop S-Series Tech 2 04-21-2013 02:03 PM
where is the vacuum line on 92 SL1 cadman33619 S-Series General 1 01-20-2012 12:42 PM
Vacuum line kingkevin8 S-Series Tech 0 11-30-2010 04:06 PM
I broke a vacuum line redcannon S-Series General 10 02-14-2010 12:38 PM
3.0 AWD Vacuum line? Solareklypz Vue Tech 2 06-08-2008 03:14 PM
