Old 09-11-2017, 07:12 PM   #1
seymourj98
seymourj98 is on a distinguished road
1994 SC2
Default DOHC timing tips
I'm installing a new timing set on my DOHC, but I'm having some issues with tension. Both cam sprockets are in the right position with the drill bits through the alignment holes, with the black links lining up with the dot on the sprockets. The cam is set to TDC with the middle of the two black links at the 6 o'clock position on the cam sprocket. However, once the chain is lined up, the guides placed in position, and the drill bits removed, the exhaust cam rotates counter-clockwise just enough to cause slack between the two cam sprockets. The intake cam does not seem to move when removing the drill bit and tends to stay in position. Does anyone have any tricks to get everything lined up without slack?
1994 Black and Gold Saturn SC2 156k
Add to seymourj98's Reputation
Rate the quality of this post and help seymourj98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
seymourj98 is offline   Reply With Quote
Old 09-11-2017, 07:45 PM   #2
Default Re: DOHC timing tips
Oil pressure fixes that without operator interference. It is not broke so do not try and fix it. If it looked like this pix it is fine. http://www.saturnfans.com/photos/sho...ming/cat/12963
Old 09-11-2017, 08:20 PM   #3
seymourj98
1994 SC2
My concern is that at the top guide, it doesn't look like that. It's not tight against the guide. It droops considerably between the two cams, despite all of the marks on the chain lining up where they should.
Old 09-11-2017, 08:38 PM   #4
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Did it look like this?
http://www.saturnfans.com/forums/att...chmentid=50739
From page 11 of my thread.
http://www.saturnfans.com/forums/sho...230898&page=11
That looks like what you are describing. We had no issues - motor runs great.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 09-11-2017, 08:49 PM   #5
seymourj98
1994 SC2
That looks about right, thanks for calming my worries
Old 09-11-2017, 10:29 PM   #6
spacetrace33
spacetrace33 is on a distinguished road
spacetrace33's Avatar
It's good idea to make two full revolutions, to verify nothing is binding up, double check all your marks, and that slack should be gone
00 SL1 Daily Driver
98 SL2 race car-not street legal by any means
01 SC2 race car-not street legal by any means
00 SL2 aka boom boom pow
99 SL2. 99 problems
Add to spacetrace33's Reputation
Rate the quality of this post and help spacetrace33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spacetrace33 is offline   Reply With Quote
Old 09-12-2017, 07:13 AM   #7
The slack will not pull out until there is oil pressure on the tensioner and once turned the marked links will not line up again unless you want to be cranking that engine for many complete revolutions. DO NOT EVER crank it counter clockwise either as it will jam the tensioner. A couple of turns for free motion is recommended though.
Old 09-15-2017, 03:37 PM   #8
spacetrace33
That's correct^as far as marks. Forgot I went and made additional marks that would like up for that. Doh!
Nuc, can you help me understand that tensioner part you said. From my observations, it works in a ratchet style, not from oil pressure. Js.
Idk. Just saying two turns worked for me as far as slack goes.
00 SL1 Daily Driver
99 SL2. 99 problems
Old 09-15-2017, 04:16 PM   #9
It is also oil pressure driven, that is why there is a small oil port behind it. The ratchet just keeps it from being completely retracted by any counterclockwise rotation of the crank such as a backfire. This feature can jam the shoe in place though.
Old 09-15-2017, 04:23 PM   #10
spacetrace33
Interesting. Thanks.
00 SL1 Daily Driver
99 SL2. 99 problems
Old 09-18-2017, 11:38 AM   #11
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
As stated, the slack is normal. If the chain is new it will be very tight once the tensioner is installed.
When you have everything else installed, the only way to install the tensioner is to remove the alignment bits for the cam sprockets. That little bit of slack you see is what allows the tensioner to be installed. The slack will disappear once the tensioner is installed. The intake sprocket should rotate counter-clockwise a bit while you install the tensioner, otherwise the bolts holes won't line up.
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
Any timing chain tips? saturn31 S-Series Tech 7 02-27-2012 02:53 PM
anyone have proper timing cover installation tips? softdrinkman S-Series Tech 12 02-23-2012 04:13 PM
proper timing cover installation tips? softdrinkman S-Series Tech 1 02-20-2012 11:12 PM
Idler Pulley Tips? '02 SC2 DOHC Fallguy S-Series Tech 12 12-28-2009 07:56 AM
just got a 95 sl2 dohc need some tips razorbladesoup S-Series Tech 21 02-26-2007 09:18 PM
