Old 09-08-2017, 08:42 AM   #1
jcarlin04068
jcarlin04068 is on a distinguished road
Dizzy '04 Ion 1 Speedometer Needle won't light.
Howdy, new to the forums. Browsed a bit unregistered and appreciate a lot of tips from many threads.
I have a 2004 Saturn ION 1 2.2L and have (in the past month) noticed my Speedometer Needle is not lit while the others (temp, fuel, tach) are perfectly fine and dim with no issues.
I've checked the wiring and there seems to be no issue there.
The needle itself accurately tells my current MPH, but it's a bit difficult to see it at night. (I work 3rd shift, so the more I can see while driving to/from work, the better.)
Is there any way to replace the little bulb itself, or do I need to get a new Instrument Cluster?
Add to jcarlin04068's Reputation
Rate the quality of this post and help jcarlin04068 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcarlin04068 is offline   Reply With Quote
Old 09-29-2017, 03:29 PM   #2
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
Default Re: '04 Ion 1 Speedometer Needle won't light.
I do not know how to replace the light in the needle.
BUT, I do know that a new instrument panel is available in the junkyard. The mileage is stored in the BCM (computer) so it doesn't matter what IP you install, the mileage should be the same.
Removing/swapping the IP is easy.
https://www.youtube.com/watch?v=EGcG...ature=youtu.be
Next time I go to a junkyard I will play around and learn more to pass on.
Peter in Lansing MI
current cars:
94 SW2 (White, automatic)
99 SL2 (Silver Plum, manual)
99 SL2 (Dark Blue, manual)
04 Ion 3 (Berry Red, 2.0L automatic)
07 Ion 3 (Cypress Green, 2.4L, manual)
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 09-30-2017, 12:17 PM   #3
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
i'll watch that youtube, but how come people tried to do themselves and it didn't work and even dealers refused to reprogram used clusters?
it's all here if you search.
PS: I saw that video before and this is about replacing bulbs and not the cluster, duh! Bad advice.
fixed/replaced so far: side mirror, window trims x4, trunk floor, radiator bushing, alternator, starter, LCA x2, sway bar bushings x2, end links x2, timing chain tensioner, O2 sensor.
Add to jacek_p's Reputation
Rate the quality of this post and help jacek_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jacek_p is offline   Reply With Quote
Oh yea I forgot to mention, my speedometer needle is... SuperGreen S-Series Tech 2 03-04-2015 09:12 PM
Speedometer Needle drm12 S-Series Tech 0 05-01-2013 01:00 AM
Speedometer needle moved, now inaccurate cluseau S-Series Tech 5 02-17-2012 11:19 AM
2002 VUE 2.2L Check Engine Light & Speedometer Needle?? scr390 Vue Tech 8 06-22-2009 08:35 AM
Sticky Speedometer Needle Indyxc S-Series Tech 6 05-08-2009 06:06 PM
