Old 09-07-2017, 11:10 PM   #1
Red5
Red5 is on a distinguished road
Red5's Avatar
2008 Astra XR
Default Throughts on Wrapped Header and TB?
Has anyone wrapped the header on their Astra? I haven't seen anyone mention it but that may just mean I missed the post. I checked in with an automotive engineer buddy and confirmed that the steel, welds, cat matrix, and 02 sensors should take the additional heat without any trouble (where an iron header would crumble). The Euro-snorkel and K&N drop-in have helped on the intake side. On the exhaust side I plan to wrap the whole affair from the header to the mid-pipe muffler. Considering port & polish on the TB but unsure it'd work as it's an electronic throttle and I've no idea how removal and reattachment would affect the sensors governing it. The VW folks bypassed the TB coolant lines thinking they introduced heat; I never did that but then the VR6 made surplus power as it was. Any opinions on TB coolant bypass?
Add to Red5's Reputation
Rate the quality of this post and help Red5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Red5 is offline   Reply With Quote
Old 09-08-2017, 01:40 AM   #2
Default Re: Throughts on Wrapped Header and TB?
Unless you're racing and making power at consistent medium to high rpm where retaining exhaust heat is useful for exhaust scavenging, you're probably wasting time and money. If you are racing this car, perhaps ceramic coating is a better idea. Here are the pros and cons from some sites that are impartial and don't have an ax to grind, selling a product. The last link is informational on how to wrap. At best, exhaust wrap will help contain radiant heat from under the hood but again only in racing conditions of extended medium to high rpm.
Aside from its intended use, I used exhaust wrap to repair a damaged flex pipe welded to a perfectly good catcon on my car instead of replacing the flex pipe/catcon section. Since the flex pipe corrugated portion (hidden by the stainless braid) is cracked and leaking exhaust, I used enough wrap to go on twice to seal and hold the flex pipe semi rigidly. This was a few months ago and has sealed off exhaust noise leaking from here, allows a certain amount of flexing and save me from replacing the section. A pair of stainless clamps holds the wrapped ends in place.
https://www.centuryperformance.com/e...o-not-use.html
http://www.autoanything.com/exhausts...orsepower-best
A car forum; https://ls1tech.com/forums/cadillac-...-question.html
How to wrap; https://exhaustsystemsguide.com/exhaust-wrap/
Old 09-08-2017, 10:16 PM   #3
Red5
Red5's Avatar
2008 Astra XR
Thank you for the links; they make it seem like wrapping is a bad idea. I don't race (only chase my car's shadow) but can't shake the idea that a bit more engine output would make a big difference in the driving experience.
Old 09-08-2017, 10:37 PM   #4
The 'butt' dyno is more frame of mind/placebo effect compared to paying for dyno time to see actual results. I wasn't aware of moisture condensing on wraps accelerates corrosion so its a dark secret to all but the racing community. Lucky for me, I just wrapped the stainless flex braid to contain exhaust noise for some years before having to deal with replacing the catcon/flex section.
Old 09-12-2017, 09:11 AM   #5
velocast
velocast has a spectacular aura aboutvelocast has a spectacular aura aboutvelocast has a spectacular aura about
When the time comes to replace my catalytic, the Eastern Catalytic 50511 from Rockauto.com, or a good header from Ebay.com will be just fine for me. My Astra with 110K miles in the pocket just pass the state emissions test without any issues. I took it to the DMV in my way coming back from work.
A wrapped header may not be suitable for my daily commuting. In a summer heavy traffic jam above 90 degrees F, an engine runs extremely hot, stop and go, idle with the A/C on for long time. A wrapped header right next to my head cylinder may give me some serious nightmares. Nobody wants to catch fire and make the news for the day. Probably an insulated exhaust-pipe wrap may help an engine to breathe better…
Add to velocast's Reputation
Rate the quality of this post and help velocast reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velocast is offline   Reply With Quote
Old 10-03-2017, 03:44 PM   #6
Red5
Red5's Avatar
2008 Astra XR
So I went with fiberglass wrap (50 feet for $14.99 delivered from amazon.com) from aft of the cat to the mid-pipe muffler. It got everywhere and I was itching for days. Afterwards I got a tip from a local who said it should have been damp going on; in case you have never heard that either I advertise the idea here. If I had it to do again I'd get the "volcanic rock" wrap as it may shed less. Also, threading 50' of wrap around the pipe every time took about an hour and 15 minutes. I should have cut it into thirds.
It does seem to quiet the nagging resonance some more; there's zero discernable difference in power but maybe it's making the whole thing a fraction more efficient on my weekly 4 hour highway trips.
New Vinyl wrapped interior and badges... vegetaarmy Astra General 26 05-03-2018 06:02 PM
leather-wrapped steering wheel jita1 Aura General 8 04-15-2008 08:09 AM
XR Leather Wrapped Steering Wheels homerec130 2008 Vue 13 08-07-2007 11:35 PM
93-94' Leather wrapped steering wheel SLeepr Classifieds 2 04-13-2004 03:52 PM
