Old 09-07-2017, 02:38 PM   #1
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Default grinding from rear at low speeds
Hey all,
Yeah, I am going to be posting on here as my 08 Nox Sport is essentially an 08 Vue, and there is not much action on the Equinox pages.
So, I have a nasty grinding/thunking sound coming from the right rear/rear diff, when I turn at slow speeds. I did get on drain and refill done on the RDM with Mobile 1 full synthetic 75-90 gear oil, which is the correct stuff for the bigger RDM in the Sport model. NO, it doesn't take Versatrak fluid. The stuff that drained out was NASTY!!! And the noise is a little bit better, but not much. Should I switch to the GM fluid for the rear??? Or should I look somewhere else. Also, I should say that I had the car in the shop, they had it on a lift and I ran it up to 60 MPH for several minutes and they listened to both rear hubs and the RDM, and no odd noises from anywhere. And te RDM stayed cool to the touch.
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
Add to lord_varon's Reputation
Rate the quality of this post and help lord_varon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lord_varon is offline   Reply With Quote
Old 09-10-2017, 09:57 PM   #2
Mustangman03
Mustangman03 has a spectacular aura aboutMustangman03 has a spectacular aura aboutMustangman03 has a spectacular aura about
2002 VUE 3.0L
Default Re: grinding from rear at low speeds
I would only use the GM fluid for the RDM's.. they seem to have a taste for only Gm fluid if is was as bad as mine (lol another story) it didn't like the mobil1 Syn and wasted what was left of the clutches... I was running a full spool for a while😂
Add to Mustangman03's Reputation
Rate the quality of this post and help Mustangman03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mustangman03 is offline   Reply With Quote
Old 09-12-2017, 08:14 AM   #3
lord_varon
lord_varon's Avatar
2008 VUE 3.6L
Mustangman,
I am taking the car to a dealership tomorrow to get something else checked out, and I will ask them about it. I know that the regular RDM in a non-sport model requires the Versatrak fluid, but the beefier rear in the sport version takes a difference fluid. It is actually the same fluid as in the rear of Corvettes, Silverados, and a couple of others. So I might have to check out those sites for more information.
John
aka
Lord_Varon
Rear end grinding noise Vuenut Vue Tech 2 08-26-2013 09:10 PM
Grinding noise from rear when accelerating nikkatnight Ion General 6 04-27-2013 04:07 AM
Grinding AWD Rear End Noise - 2005 V6 Ollie Vue General 48 03-01-2011 02:43 PM
rear drum grinding donis99 S-Series Tech 0 10-10-2010 03:27 PM
Revisiting the grinding noise at low speeds while wheels are turned... TheSlayer Vue Tech 9 09-23-2008 05:45 PM
