Old 09-06-2017, 03:41 AM   #1
JWanta79
JWanta79 is on a distinguished road
Default Reverse speed limiter on 98 SL2
I have an auto 1998 SL2 that I'm using for a demo derby type race, I've already done one with it and everything was great, until I started my reverse lap. Apparently s-series Saturn's have a speed limiter in reverse right around 25 MPH, and it is pretty rough trying to go around a half mile track at 25. I was wondering if anyone had any idea how to disable the reverse speed governor, I don't really care if its going to damage the car in the long run as I really only need it to run for about 30 min.
Add to JWanta79's Reputation
Rate the quality of this post and help JWanta79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JWanta79 is offline   Reply With Quote
Old 09-06-2017, 06:48 AM   #2
Default Re: Reverse speed limiter on 98 SL2
Swap a 5spd in and pull the VSS...if the PCM doesn't know how fast you're going it can't limit your speed. Pretty sure the automatic's can't handle having the VSS unplugged and still shift but I suppose its worth trying.
Reverse rev limiter? Infinitrium S-Series Tech 1 01-25-2011 06:54 PM
Removing the Speed Limiter: Disconnecting the Input and Output Speed Sensors AlexofNazareth S-Series Mods 35 11-19-2010 06:21 PM
Reverse rev limiter?? Greg2347 S-Series Tech 11 07-26-2008 07:58 AM
Reverse Speed Limiter ProDarwin L-Series Tech 17 03-19-2003 06:39 AM
Speed limiter WHITE98SL2 General Saturn Discussion 18 05-31-2002 07:58 PM
