Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 09-05-2017, 05:34 PM   #1
scayetanot
scayetanot is on a distinguished road
Dizzy Catalytic converter... I am lost
Hi,
I have a P0442 showing up on my Saturn vue 2009 Hybrid.
Is there a way for me to test if it's a cat issue or just a reading issue by the sensor ?
Also I would like to be one and replace it my self but I am lost on what to by because I found
- a small part (check on autozone. sorry I can't post url) which seems to be just the cat converter and I have to fix back on the exhaust line
- bug part with this cat converter + all exhaust line between the engine and prior to the muffler I think. I just have to unscrew the old and put the new one
I do not which one I have to buy. the second one seems to be only the cat converter but I do not know If I can just buy this and plug it or if it will require to cut from the flow the old one and solder the new one or if it's a kind of plug and fix.
Any idea, help will be great.
Add to scayetanot's Reputation
Rate the quality of this post and help scayetanot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scayetanot is offline   Reply With Quote
Old 09-05-2017, 07:05 PM   #2
Default Re: Catalytic converter... I am lost
P0442 in general means a small leak in the evaporative emission control system. Most small leaks of fuel vapors may be a worn gas cap seal or dirt on seal/fuel fill neck preventing a good seal. The fuel system is tested as a vehicle is driven for vapor leaks - fuel vapors are stored in charcoal canisters and fed into running engines. Emissions controls require sealing off the fuel system and testing for fuel tank pressure and vacuum as a way to determine if a vapor leak occurred.
Clean and inspect the fuel cap and fuel neck, replace the cap if necessary and see if the error code goes away on its own. It becomes complicated to troubleshoot plumbing if a leak is anywhere else.
Old 09-06-2017, 05:40 PM   #3
scayetanot
Sorry I totally put the wrong code. it's P0421 - cat converter below threshold.
For the P0442, I smell gas from time to time coming from the front. I alreday the caniser solenoid and vent to replace them
Old 09-06-2017, 06:19 PM   #4
P0421 catalytic converter below efficiency. This is either a worn out catcon or downstream O2 sensor. One inexpensive repair may be using spark plug anti foulers repurposed as O2 sensor extenders to move the sensor further away from the catcon exhaust stream. Search for them as they come in different sizes. Its basically a steel threaded bushing to screw into the exhaust bung and screwing in the sensor to the steel bushing. Its an alternative to either replacing the O2 sensor or catcon. Less exhaust sampling sometimes works to erase the error code.
When considering replacing exhaust system parts, O2 sensors and catcon are expensive so years and mileage have a bearing on when to replace parts. There's also a long factory warranty on emissions equipment. Check your owner's manual for warranty info. Some may have 8yrs/80k miles or more.
Old 09-17-2017, 08:35 AM   #5
atikovi
Try an O2 sensor spacer first. http://o2-simulators.com/?gclid=CJTi...FUxlfAod5x4k2w
Add to atikovi's Reputation
Catalytic converter and oil pan Adomka S-Series General 0 05-25-2014 08:26 PM
catalytic converter trm65 Astra Tech 1 06-13-2013 02:44 PM
Catalytic Converter rgrafton S-Series Tech 23 03-17-2013 04:39 AM
Catalytic Converter help! saturnmommy S-Series Tech 11 11-11-2012 08:04 PM
catalytic converter Al Scott S-Series General 10 04-16-2007 09:46 AM
