Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 09-04-2017, 05:48 PM   #1
normdude
normdude is on a distinguished road
2003 VUE 2.4L
Default Having clutch problems
Lost my clutch petal one day. No signs of fluid or anything. I did check it and there was bearly any fluid left. So I pulled everything apart and changed the whole clutch. I thought I'd have a pedal but it's still the same. My question is from the firewall the pedal goes to this round looking thing to the master. What is that?? Can that be my problem? I did the gravity bleed still no pedal.
It's round, maybe the size of a sliver dollar but thicker. And has a line to it that goes to the slave.
Thanks for any help
Add to normdude's Reputation
Rate the quality of this post and help normdude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
normdude is offline   Reply With Quote
Old 09-05-2017, 09:45 AM   #2
waiter21
2003 VUE 2.2L
Default Re: Having clutch problems
I assume you changed the slave cylinder when you changed the clutch...
There is a special procedure to bleed the clutch. The problem is, there is no full flow through the slave where you can bleed the air, so you rely on the air to float to the top. It takes a little coaxing to get it to do this, that why a vacuum bleed is preferred. Basically in the manual bleed, you push fluid into the slave, then this will push the air to the top.
Here is how I changed the clutch and slave:
http://www.saturnfans.com/forums/sho...d.php?t=222576
Here is how I bleed the clutch:
http://www.saturnfans.com/forums/sho...d.php?t=222577
Add to waiter21's Reputation
New clutch but problems ? Endders S-Series Tech 6 02-13-2012 03:31 AM
Clutch Problems? Duck L-Series Tech 1 01-12-2012 09:44 PM
Clutch problems? thomascald S-Series Tech 2 01-04-2011 12:00 PM
Possible clutch problems? btf_firefighter S-Series General 1 12-24-2010 03:12 PM
Clutch Fork related to clutch problems? MikeNW S-Series Tech 0 06-25-2008 12:27 AM
