Old 11-04-2017, 04:20 PM   #41
Default Re: 2002 Saturn SL1 Quill Seal Removal
You are supposed to transfer the pins from the old flywheel to the new one. They punch out from the back side. The holes for pins are present. More than likely your issue is air in the hydraulics. That would be the part I would replace. If the other flywheel has pins then use it as they are all the same. The yellow spring is not compressed enough.
Old 11-04-2017, 04:41 PM   #42
From the service manual:
Clutch Pressure Plate Adjustment
Place clutch cover on a flat surface with clutch plate fingers facing up. Using two screwdrivers, push counter-clockwise on two adjuster ring tabs to prevent the adjuster ring tabs from suddenly moving forward. At the same time, using a press, depress the clutch plate fingers until the adjuster ring tabs begin to move freely.
Compress the springs by pushing the adjuster ring tabs counter-clockwise. The clutch is fully adjusted when the compressed spring length is between 15 mm - 20 mm (0.59 in - 0.79 in).
Add to ssicarman's Reputation
Old 11-04-2017, 07:36 PM   #43
uccoskun
uccoskun is on a distinguished road
Thank you two for quick reply.
Tomorrow, I will remove the clutch and compress it again. I think the length is almost 20 mm but I will compress the spring all the way in.
I will stick with the brute flywheel as I get rid of the original flywheel weeks ago after the first installation.
Thank you again.
Add to uccoskun's Reputation
Rate the quality of this post and help uccoskun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
uccoskun is offline   Reply With Quote
Old 11-05-2017, 02:07 PM   #44
uccoskun
Hello, I reset the pressure plate and install the clutch. I mounted the transmission but have not torqued them yet. I will torque the bolts when rains stops.
I took a picture of the pressure plate after resetting. Some of the fingers are shy of the hard stop but I cannot push them any closer since the rest of them (red circled ones in the picture) are almost touching the limits.
I will order master cylinder/slave cylinder shortly.
Thank you.
before and after pictures:
Old 11-06-2017, 12:37 PM   #45
The hydraulics do not survive shipping very well if at all.
Old 11-11-2017, 06:44 PM   #46
uccoskun
well,
I think the cylinders have survived the shipment relatively well. With the new cylinder assembly, I can put it into the first gear but it is still difficult. It is not normal and I kinda feel like I abuse the synchronization ring more than I should. I can engage the reverse gear easily as expected. Only first gear is problematic (rest of the gears are easy).
Independently, I think I left something loose in the suspension. I will check it tomorrow.
I do not want to open this car again. If the system adjust soon, I might sell this car.
Thank you all.
Old 11-11-2017, 07:10 PM   #47
If it works at all the hydraulics improve with age, likewise the clutch. If you can get into first with the engine running and car stopped then it is fine. Downshifting to 1st serves no real purpose.
Old 11-11-2017, 08:55 PM   #48
uccoskun
That's really good news. I worry about wearing out the sycronizing ring. I guess i will see what happens. How long will it take to get better? I feel very good now.
Thank you.
Old 11-12-2017, 09:27 AM   #49
How long depends on many unknowns.
Exactly what are you using for fluid?
If you disengage the clutch and wait for a 2 count the shift from neutral to 1st should be easier and the blocking ring does not have to slow down or speed up a box of gears as much. Blocking ring wear will be highly dependent on fluid and it is critical to note that transmission was designed for a special fluid --it was not just Dexron-3.
Old 11-12-2017, 10:45 AM   #50
uccoskun
I waked up at at 7 am and removed the wheel to check the links. I found that the locking nut on one of the the tie rod ends was loose. I have tightened it and now it feels better. There is still something else though.
The clutch starts to feel better already, i hope it is not temporary. I used walmart's supertech dextron3 mercon brand fluid(it was only available brand at walmart). should I replace it with something else.
Old 11-13-2017, 10:37 AM   #51
Run it for awhile and see how it goes. The dex/merc universal fluid is too thin actually and the Dex-6 is even thinner so the fix gets rather expensive if required. The thicker fluids will increase the hydraulic coupling between the gears which eases the shifting. Clutch must be functioning properly for anything else to be effective. There really is not much in the trans to "wear out" that fouls up shifting.
Quill bearing seal leak! atown88 General Saturn Discussion 1 04-27-2017 09:00 PM
Infamous input shaft seal (quill bearing) questions I could not find answers to The Mad Hatter S-Series Tech 10 08-19-2015 07:58 AM
Quill bearing seal leak? wb 86 S-Series Tech 4 09-15-2013 02:33 PM
Question on Quill seal in Manual Transaxle NGFD14 S-Series Tech 3 05-31-2010 04:07 PM
Quill Seal/Bearing & FSM jjbendo S-Series Tech 7 09-28-2009 11:53 AM
