Old 09-02-2017, 02:09 PM   #1
83trekker
83trekker is on a distinguished road
Default 06 ion PO014 and P0442
Got thses 2 codes on my 06 ion.
I am searching and seeing VVT and camshaft sensors , any way to narrow this down before i start throwing parts at this?
Any suggestions greatly appreciated.
Thanks
Add to 83trekker's Reputation
Rate the quality of this post and help 83trekker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
83trekker is offline   Reply With Quote
Old 09-03-2017, 11:47 AM   #2
83trekker
Default Re: 06 ion PO014 and P0442
Bump for help thanks
Old 09-03-2017, 11:56 AM   #3
Did you try searching past threads within these forums for similar error codes and solutions?
Old 09-03-2017, 12:25 PM   #4
83trekker
I have and it has reported cam sensor or vvt selenoids and one person with going full synthetic oil and good filter, just wondering a way to narrow it down.
Old 09-03-2017, 01:00 PM   #5
As I understand variable valve timing, Ions may use one or two electro hydraulic solenoids to control oil pressure to advance or retard intake/exhaust cams. I've read about motor oil fouling the screen filters (choking oil pressure/supply?) causing problems. Some found removing the screens eliminates the problem and sticking to oil change recommendations (ignoring it creates more problems from contaminated oil). While synthetic oil is better than regular oil, unless regular oil and filter changes are performed, it seems vvt engines suffer from lack of periodic oil changes and real world issues not found from testing before VVTs debuted. Switching to synthetic oil won't make a problem go away if changing oil is ignored. I don't know if P0014 points to intake or exhaust control valve. The cam sensor is strictly used to detect cam shaft relative position in timing. Either it works or not as it simply reports cam position to the ecm. The ecm uses sensors to determine everything to run an engine. All we can do is put fuel in the tank, startup and press the pedal. Everything else is controlled by the engine computer.
Old 09-12-2017, 08:55 AM   #6
83trekker
So i cleared the code and now it has not come back on. I got the solenoids from the junk yard to swap out and see, if the code comes back on. Will update if they do come back. Thanks
Old 10-03-2017, 08:46 PM   #7
83trekker
so this code came back and now i have po455 also
Old 10-03-2017, 09:17 PM   #8
P0442 Evap Emission Control Small Leak Detected
P0455 Evap System Large Leak Detected
Read more at: https://www.obd-codes.com/p0455
Copyright OBD-Codes.com
Old 10-03-2017, 10:07 PM   #9
83trekker
screw it i built a smoke machine, where do i introduce the smoke into the system for a evap leak? this will make it easier to diagnose.
if its the evap valve in the rear of the car , and the valve is just bad will the smoke help with that?
07 Ion P0442 Leith1812 Ion Tech 7 04-29-2016 10:41 AM
The old DTC P0442 Not a Number S-Series General 1 01-23-2016 03:16 PM
p0442 fix laser3kw S-Series Tech 1 10-09-2015 01:43 PM
p0442 again and again AND AGAIN Cortana S-Series Tech 2 01-17-2007 07:23 AM
P0442 Cortana S-Series General 2 11-28-2006 11:48 AM
