Old 08-20-2017, 10:55 PM   #1
Emmaus
Emmaus is on a distinguished road
Default SL-2 Misses when it's cold outside
The past few winters my SL-2 has been missing badly. All the cylinders have thrown the error code (P030x).
I have gone through and checked or replaced everything I know of and the problem persists until the outside temperature warms up in the Spring.
[Compression]
180, 170, 170, 170
[Fuel]
New filter, checked fuel pressure regulator/fuel pressure, swapped fuel injectors, new PCV
[Ignition]
New spark plugs and wires, new coils, new MAP sensor, new EGR valve, new Crank position sensor, new temp sensors (engine and air intake), cleaned throttle body, new thermostat
There is a noticeable loss of power when the missing occurs.
It usually happens after a few miles of normal operations.
It is fine until it starts to miss. Then the miss/power loss is fairly consistent.
The problem starts when the outside temperature is around 40 degF or below. It doesn't seem to be worse below 0 degF than at 40 degF.
My guess is it's a thermal sensor problem when the system transitions from a cold start condition to normal operating engine temperature.
Are there more temperature sensors?
How can I verify the temp sensor wiring?
1997 Saturn SL-2
214,000 miles
DOHC
Automatic Transmission
Add to Emmaus's Reputation
Rate the quality of this post and help Emmaus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Emmaus is offline   Reply With Quote
Old 08-20-2017, 11:20 PM   #2
Default Re: SL-2 Misses when it's cold outside
Loose cat guts (catcon disintegrated) blocking exhaust flow?
Old 08-22-2017, 12:06 AM   #3
Emmaus
Purrrrrhaps.
I will look into it.
Engine misses at low rpm's niamhblack13 S-Series Tech 0 11-08-2011 01:42 AM
'99 SL1 misses intermittently cathcycler S-Series Tech 19 12-19-2007 10:54 AM
97 SL2 Misses when cold parkiespop S-Series General 24 05-15-2005 12:22 AM
Engine Misses HazManRon S-Series Tech 3 04-06-2005 02:09 PM
Cold engine fine, warm engine misses ?? Scyan S-Series Tech 9 11-04-2002 11:08 PM
