Old 09-25-2017, 03:02 AM   #41
Default Re: 2000 Saturn Ls1 Fuel sending Unit
Please verify whether there's spark or not. Testing can be done by you or anyone reading suggestions given. Spark indicates the PCM is operating and a fuel problem may be the only issue besides possible loss of compression. If spark doesn't exist along with a lack of fuel found on spark plugs, this suggests a faulty crank position sensor. If you give confusing information, this delays diagnosing and misleads everyone. You are in the only position to provide accurate info as no one here is standing next to you or the car to observe symptoms and provide feedback.
Old 09-25-2017, 07:41 AM   #42
floridasl22002
Excuse me guys for butting in, but I see folks suggesting removing wires from the coil to check for spark.
The 4 pot Saturn, like the V6 has coil packs or ignition cassetes as some like to call them. There are no wires as such. It's a plug & play unit. Could it not be the simple case the unit needs replacing?
Old 11-16-2017, 11:05 AM   #43
Lady_saturn
Lady_saturn is on a distinguished road
UPDATE****
Finally decided to take my car to a shop the end of sep and guess what itís still sitting there. They have been unable to tell me what is going on and it is going on two months now I think that it is time for a new car I guess .. I Just wanted to say thank you to all of your that responded. Have a good future Saturn Fans..
Add to Lady_saturn's Reputation
Rate the quality of this post and help Lady_saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lady_saturn is offline   Reply With Quote
Old 11-17-2017, 10:32 AM   #44
pierrot
pierrot's Avatar
I'm sorry to learn that this problem has not been corrected. If you have spark and fuel pressure, generally, the engine should start. As fdryer has mentioned, there could be a bad crankshaft position sensor. I would like to add that the Inition Control Module (ICM) was subject to a recall in late '01 or '02. Was this part ever replaced on your car? If you don't know you, go to
http://www.gm.com/owner-assistance/saturn.html>Recalls>enter VIN>search
to find outstanding or completed recall items related to your car.
I really think that something has been overlooked. Starting a car's engine isn't all that hard. The basic ingredients: proper fuel delivery, spark, and compression. We've never had an answer regarding a compression test with this car's engine so as to verify whether or not a timing problem, or other related compression issue may exist. BTW, what tests or processes has the repair shop undertaken to attempt to diagnose and correct this no start problem?
Lady saturn, I understand your seeing the likelihood of needing to replace this car. I would never be in disagreement with a person who wishes to replace their car. However, I don't believe this has been handled correctly and, as a result, it may be leading you to an unwarranted conclusion.
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 11:34 AM
Fuel Sending Unit jswingchun S-Series General 1 08-21-2006 09:27 AM
Where can I buy a fuel sending unit for a 92 SL turbobuick33 S-Series General 5 08-28-2005 09:50 PM
fuel sending unit ammotrooper General Saturn Discussion 10 06-03-2003 06:28 AM
Fuel Sending unit? SLeepr Miscellaneous Tech 2 11-07-2002 09:47 PM
