Old 08-19-2017, 12:19 PM   #1
Therowland
Therowland is on a distinguished road
2002 VUE 3.0L
Default 2002 Saturn Vue SES
Recently purchased a 2002 Saturn Vue 3.0L. Had driven it about 30 miles. Drove 20 miles on the hwy and the SES light came on as well as check oil light came on but as I got off the hwy. after going again they both shut off and now the SES light is back on again. Nothing seems to be wrong and I know that I need to have the code checked but maybe someone could give me some ideas as to what this could be before I get the chance to. It has 159000 miles on it. I did have the A/C running on full blast but I would typically assume an O2 sensor as I've had that issue in the past with other vehicles. Suggestions?
Thank You
Add to Therowland's Reputation
Rate the quality of this post and help Therowland reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Therowland is offline   Reply With Quote
Old 08-19-2017, 07:14 PM   #2
atikovi
Default Re: 2002 Saturn Vue SES
Anythings a guess at this point. I'll guess catalytic converter.
Add to atikovi's Reputation
Old 08-19-2017, 10:17 PM   #3
billysvue
Yeah, with 160Kmiles, spark plugs,cats/Osensors could all be toast. need codes, though, of course.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-19-2017, 11:10 PM   #4
tecky11
tecky11 is on a distinguished road
fore warning you will need to buy special tools to work on this motor. you will need torx bits, 8 inch 1/4 inch drive extention, star bits to remove cover over park plugs, and somthing to hold intake up while working on cyl 1,3,5
2003 saturn vue 3.0 v6
1973 International 345 v8 auto
2007 saturn Ion 2.2/auto donor car
Add to tecky11's Reputation
Rate the quality of this post and help tecky11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tecky11 is offline   Reply With Quote
Old 08-20-2017, 06:55 AM   #5
atikovi
OP doesn't own a scan tool, doubt he would even attempt to get into the engine.
Old 08-20-2017, 08:46 AM   #6
Chazberry
Chazberry's Avatar
Which Oil Light are you referring to?
Add to Chazberry's Reputation
Old 08-20-2017, 10:42 AM   #7
Therowland
2002 VUE 3.0L
I had the codes ran. Turns out to be the VSS. Although my other question but this is almost a general any vehicle question. Cause I'm sure no matter the vehicle the answer could be identical. If my turn signals work off an on I would assume there is a short either in the turn signal switch or the wiring correct? Just trying to ask questions as I am new to owning a Saturn and only a semi DIY mechanic. Mostly know what I know from doing the work I personally have done myself.
Old 08-20-2017, 10:48 AM   #8
billysvue
I would suspect the stalk switch... Maybe some plastic-safe electronic parts cleaner( spray) can help it once you get it exposed.
'17 Suby Forester
2002 saturn sl1 eljonsaturn Classifieds 0 08-04-2016 10:06 PM
2002 Saturn sl1 s, e, s newsaturnowner1 S-Series General 6 04-02-2014 10:26 PM
My $397 2002 Saturn Vue V6... What will it need travlincub321 Vue General 15 11-24-2012 01:24 AM
ECM on a Saturn 2002 js8661 L-Series General 3 01-28-2006 09:34 AM
2002 Saturn VUE CincyVUE Classifieds 1 01-19-2003 12:24 PM
