Old 08-18-2017, 12:13 PM   #1
dylank
dylank is just really nicedylank is just really nicedylank is just really nicedylank is just really nice
2000 SL2
Default 2000 Saturn sl2 won't start
My 290,000 mile 2000 Saturn sl2 won't start. Automatic dohc. I drive it 150 miles, turned it off. Now going to start it all the lights come on, radio blower etc, no crank. Checked battery with multimeter, and it is in range. Checked all fuses all good. Swapped all relays still exact same thing. Now going to check starter for power, luckily I have a few tools with me. But I'm posting this as I'm broken down the the side of the road and could use any input
Add to dylank's Reputation
Rate the quality of this post and help dylank reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dylank is offline   Reply With Quote
Old 08-18-2017, 12:50 PM   #2
dylank
2000 SL2
Default Re: 2000 Saturn sl2 won't start
Can I test the starter solenoid purple wire with a multimeter only?
Old 08-18-2017, 01:05 PM   #3
billr
Yes, you should have battery voltage (about 12V) between the PPL wire and the starter case when the key is turned trying to crank.
Add to billr's Reputation
Old 08-18-2017, 01:21 PM   #4
gas3987
gas3987 is on a distinguished road
Are you alone? If you could find a way to tap on the starter while someone holds the key in crank, it may get you home at least. Sounds like the starter may have called it quits.
Add to gas3987's Reputation
Rate the quality of this post and help gas3987 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gas3987 is offline   Reply With Quote
Old 08-18-2017, 01:42 PM   #5
When my starter was dying, it would fail hot. That is, if I turned the engine off and tried to start again while the engine was hot, it would not crank.
After about 20~25 minutes of cooling down, it would work again. Good luck; if it is the starter, the DB Electrical one is a good replacement
Old 08-18-2017, 01:44 PM   #6
Whacking the starter body a few times may give you another start or more if its the original starter. If it gets you going, get it either to a shop or home and determine if its the original starter that's finally worn out. 12v on the small purple wire while starting indicates power is getting to the starter solenoid but the solenoid may be dead unless this wire is loose.
Old 08-18-2017, 02:30 PM   #7
Casper50
Casper50 will become famous soon enough
2001 SC1
Where are you at in Colorado? I might be able to give you a hand. If there isn't any power to the starter solenoid while cranking then it will probably be a neutral safety switch. Let me know if I can help. I'm in North Denver.
Add to Casper50's Reputation
Rate the quality of this post and help Casper50 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Casper50 is offline   Reply With Quote
2000 Saturn SL2 won't start/run Steven2000 S-Series Tech 7 01-16-2015 06:04 AM
2000 saturn won't start ry7662 S-Series General 3 05-15-2012 08:59 AM
2000 Saturn LW2 V6 won't start krarifjan L-Series Tech 6 08-22-2011 09:17 AM
2000 Saturn SL2 won't start JoJo S-Series Tech 10 06-01-2009 09:43 AM
2000 saturn won't start Budge7 S-Series General 6 12-30-2004 06:44 AM
