Old 08-17-2017, 10:16 AM   #1
2000sl1blue
2000sl1blue has a spectacular aura about2000sl1blue has a spectacular aura about2000sl1blue has a spectacular aura about
2007 SKY Red Line
Default Crankshaft "tooth"?
Has anybody had experience buying a new crankshaft and having it come without the "tooth"? I was about to put on the timing chain and realized I cannot get the crank pulley on because it's missing! I looked at my old one and sure enough, it's there.. Heres a picture of what I mean, the rectangle the goes into the groove. I really hope this is able to be transplanted as the engine is already in.. If not any tips on what I could weld in the new crankshaft to get around it?
Add to 2000sl1blue's Reputation
Rate the quality of this post and help 2000sl1blue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000sl1blue is offline   Reply With Quote
Old 08-17-2017, 10:56 AM   #2
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Default Re: Crankshaft "tooth"?
You mean the KEYWAY?
I would have thought it needed to be kept from the old crankshaft and reused.
Most machine shops (or Mc Master-Carr) stock key stock in various sizes...1/4", 5/16" etc and should be able to cut you a new 'key' to insert into the Keyway.
Don't weld anything, just insert the new key based on whatever width square stock fits. Hopefully, it is not of case hardened tool stock material.
Old 08-17-2017, 11:00 AM   #3
2000sl1blue
2007 SKY Red Line
Should I try to hammer out the old crankshft?
Old 08-17-2017, 11:25 AM   #4
whastings
whastings is on a distinguished road
whastings's Avatar
1999 SW2
It should come out, yes. I usually use a brass punch to take them out. But it should tap out pretty easily.
Add to whastings's Reputation
Rate the quality of this post and help whastings reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whastings is offline   Reply With Quote
Old 08-17-2017, 12:29 PM   #5
2000sl1blue
2007 SKY Red Line
So I got it off! I used a punch. Issue now is when I tried to put it on the new crankshaft it slipped and went into the oil pan!!!! Is this magnetic? If I cant get it out of the oil pan will it just sit there without harming anything?
Old 08-17-2017, 12:32 PM   #6
Get a retriever magnet and get it out of there.
Old 08-17-2017, 02:38 PM   #7
2000sl1blue
2007 SKY Red Line
I found a great one at napa which was flexible plus has a claw! I'm thankful it's not aluminum.. It came out in seconds...
Old 08-17-2017, 05:11 PM   #8
keys are always steel. They are usually easy to retrieve.
Old 08-17-2017, 06:38 PM   #9
RobertGary1
That would be a serious amount of force to put on an aluminum key!
-Robert
RobertGary1 is online now   Reply With Quote
Starter relay violently failed, digital display reads "PWR STR" and "COOLANT" tb123a Ion General 6 10-24-2015 03:20 PM
Saturn S Series Photo Contest!- April- Car "Selfies" and "Twin Cars"!!! blackbeard S-Series General 18 05-04-2014 10:06 AM
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota Charlie General Saturn Discussion 20 02-25-2011 04:11 PM
cam timing is a half tooth "off"- i think frankv569 S-Series Tech 8 04-11-2010 01:33 PM
Vin "7" Vin "8" Vin "9" brake pads/rotors universal? demoncamber S-Series Tech 4 09-09-2009 11:35 AM
