Old 08-17-2017, 09:42 AM   #1
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Best replacement MAF brand?
Would anyone care to give an opinion on the best replacement MAF brand for the 3.0L? Based on actual experience please.
I am not looking for a long winded dissertation on how a MAF works.
Thanks.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
Old 08-18-2017, 02:20 PM   #2
Dsaturn
Dsaturn has a spectacular aura aboutDsaturn has a spectacular aura aboutDsaturn has a spectacular aura about
2001 L-Series 2.2L Sedan
Default Re: Best replacement MAF brand?
ACdelco is OEM so I would say that would be best.
Add to Dsaturn's Reputation
Rate the quality of this post and help Dsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dsaturn is offline   Reply With Quote
Old 08-18-2017, 02:54 PM   #3
Claybury
Claybury's Avatar
OEM is Bosch. The quality on the Bosch replacements seems to be quite variable. So I am wondering if anyone has had good luck with anything else.
Otherwise it's Bosch, cross fingers, and hope to get 20K out of it. Assuming it's not 30 G/S with the engine off.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
Old 08-18-2017, 02:59 PM   #4
Dsaturn
Rock auto list ACDELCO 213809 {#09193533, 90528435, 93171760} as OEM.
Old 08-18-2017, 04:26 PM   #5
Claybury
Claybury's Avatar
It's AC Delco on the box and Bosch inside the box.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
Old 08-18-2017, 06:29 PM   #6
pierrot
pierrot's Avatar
The sensor is removeable from its cylindrical housing, but you need a special torx bit which can fit a screw with the little "security tip" in the middle of the torx shaping at the screw head (assuming your housing has this type of screw on it). If the AC Delco product is a Bosch item that's been reboxed - and apparently you're not happy with a Bosch product - then I would choose the Delphi brand MAF Sensor.
279,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 08-19-2017, 08:55 AM   #7
soulsurvives
soulsurvives has a spectacular aura aboutsoulsurvives has a spectacular aura aboutsoulsurvives has a spectacular aura about
2002 L-Series 2.2L Sedan
The OEM on our 2003 is still fine at 110k. If it dies then in will go another OEM.
Add to soulsurvives's Reputation
Rate the quality of this post and help soulsurvives reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
soulsurvives is offline   Reply With Quote
Old 08-19-2017, 12:42 PM   #8
Russet
2002 L-Series 3.0L Sedan
Replaced mine with Bosch and no problems. So unless there is a history of problem Bosch to show otherwise this is a opinionated thread only.
Add to Russet's Reputation
Old 08-20-2017, 07:30 AM   #9
soulsurvives
Lmfao!!! In the first sentence of this thread is the op asking for opinions, I think he got what he wanted.
What brand for replacement clutch Red's 99 S-Series Tech 7 04-08-2012 09:46 PM
Replacement wheel bearing brand? slonoma98 Vue Tech 2 07-21-2011 07:34 PM
Replacement ECTS, what brand? Sidneyaks S-Series General 17 06-13-2011 06:07 PM
Another brand of replacement H11 bulb tomlct L-Series General 1 10-08-2006 10:59 PM
WTS: Brand New 91-99 OEM Replacement Luk Clutch Kit LoveMySaturn Classifieds 3 06-10-2005 09:15 AM
