Old 08-12-2017, 09:18 PM   #1
Ablack07
Ablack07 is on a distinguished road
Default 1997 Saturn SL starting issue
So I bought this car for a deal. It runs and drives but won't start sometimes. If you wiggle the wiring behind the fuse box, most of the time it will start. During this dance of electrical bs, the door locks click and make noise, all four doors, and the hazards flash like security has been turned on. I've unhooked several harnesses and have looked through wires for any I can see broken etc... what am I missing?
Add to Ablack07's Reputation
Rate the quality of this post and help Ablack07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ablack07 is offline   Reply With Quote
Old 08-12-2017, 10:04 PM   #2
Default Re: 1997 Saturn SL starting issue
Pin F5 is burnt up, may possibly be able to tear it apart and fix it but the long-term fix is to not use the cigarette lighter outlet to power anything, ever and replace the fusebox hopefully with one that hasn't been used as a charger.
More info: http://www.saturnfans.com/forums/sho...d.php?t=173989
Old 08-12-2017, 10:27 PM   #3
Ablack07
Thanks... I'll take a look at it
1997 saturn starting problem luked S-Series Tech 2 04-18-2016 12:38 PM
1997 Saturn SW1 not starting. Is it related to missing serpentine belt? lolobree S-Series Tech 5 01-31-2015 02:34 PM
1997 saturn sc1 starting problems standndlight S-Series Tech 10 01-29-2013 09:24 AM
SW2 1997 Starting Issue captsam S-Series Tech 3 07-05-2010 06:46 PM
1997 SC starting issue pyronn S-Series Tech 4 05-04-2009 05:43 PM
