Old 08-12-2017, 04:20 PM   #1
Default Spark plug reading - this is different
Plugs are about 6 months old, don't know how well it's showing up in the pics.
Oil on plugs 1, 3, and 4 so planning on new gasket. Gap does not look bad to the eyeball, did not check though. #4 has some damage to the insulator, looks like
The new thing is, each plug has a narrow notch in the electrode. Never seen that before. What causes this (spark being narrow and long, I assume), and how do I remedy it? Car runs fine, otherwise, so this surprised me.
The attached pics are the first set I've put in the car, the set in the car when I bought it can be seen here (no notches, but they were rusty and the gap was huge, very worn plugs)
http://www.saturnfans.com/forums/sho...postcount=5077
Thanks in advance
7/2010 Craigslist white 1997 SC2 project-one day
11/2016 red 2002 SC2 115k
Old 08-12-2017, 04:49 PM   #2
OldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant future
Default Re: Spark plug reading - this is different
Those are BKR5E plugs and they come with that split center electrode. They are V-Power design.
Try a BKR6E V-Power plug, those look to be running a bit on the hot side and you are not burning lots of oil. Be sure you get the V-Power plug.
Old 08-12-2017, 05:11 PM   #3
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Yes, those plugs look a little "Toasty" Try a heat range colder. Looks like some evidence of preignition as well on at least one of them.
2004 L-Series Wagon 2.2 218K Miles
2004 L Series Wagon 2.2 68K Miles
2004 L-Series Wagon 3.0 48K Miles
Add to rb6667's Reputation
rb6667 is online now   Reply With Quote
Old 08-12-2017, 05:35 PM   #4
billysvue
AS mentioned, the plugs looked baked and flaked away glazing on insulator is a giveaway.
Ever hear detonation/pinging...
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-12-2017, 06:44 PM   #5
That is most likely cooked on carbon. Plugs have been used way past replace time.
Old 08-12-2017, 07:13 PM   #6
billysvue
Yeah, I suppose, or I've even seen aluminum "plasma coating" from runaway detonation eroding the piston dome.
'17 Suby Forester
Old 08-12-2017, 07:19 PM   #7
Very few if any of these engines suffer any preignition unless they are burning 85 octane fuel with the knock sensor failed and an SES light on. Other designs do indeed have issues though.
Old 08-13-2017, 09:36 PM   #8
Thanks, guys!
Apparently, I'm an idiot, not only did I forget the type of plugs I used, now that you mention it, I am sure I noticed the notch when I installed them back in February, thought to myself, "Huh, that's interesting" and them completely forgot about it
On the plus side, got some good advice on going to a colder plug, so I've got that going for me, which is nice.
No detonation or pinging, no codes (other a secondary O2 circuit which I keep forgetting to do something about, but do check the codes frequently to make sure something else hasn't popped up)
Will order plugs, wires, and gasket.
Side note: the wires are marked Packard, could be the OEM wires. Others have used the OEM wires over 100k miles without problems. Don't seem to be having any problems with them either, so did not change them whan I last changed plugs
Old 08-14-2017, 09:38 AM   #9
That "Packard" is just a name. Standard Motor Products Blue Streak if you can find anyone who can order them for you. Other than that plain old mid priced wires work and none of them actually last for 100,000 miles in a Saturn as that is equivalent to 200,000 miles in conventional ignition.
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Reading spark plugs el diablo viejo S-Series General 1 03-13-2013 02:20 PM
1998 sl2- oil where the spark plug boot meets the spark plug in 1st cylender scrapmedallord S-Series Tech 7 08-14-2009 11:31 PM
"Reading" a Spark Plug DualCamCoupe How-To Library 3 08-31-2003 10:20 AM
'reading' spark plugs... LI 350 Miscellaneous Tech 5 01-13-2002 10:49 PM
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
