Old 07-31-2017, 09:28 PM   #1
FreedomSoftware
FreedomSoftware is on a distinguished road
2008 Astra XR
Default Throttle Body
So I was driving a bit ago down a country road doing about 45. My check engine light came on and it felt like the top half of my gas peddle didn't do anything. Has any one encountered this issue? I'm gonna get a scanner from work tomorrow and get the code for the light and see exactly what it is. I cleaned the throttle body about 5 or 6 months ago so I feel that's not the issue.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-Thule Roof Rack (and wind fairing)
-1.25" Lowered
-Windows Tint all around
-JVC Head unit
-Dual 12" Subs
Add to FreedomSoftware's Reputation
Rate the quality of this post and help FreedomSoftware reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FreedomSoftware is offline   Reply With Quote
Old 08-01-2017, 07:21 AM   #2
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Default Re: Throttle Body
Yeah, check the code. The only time I seriously lost power was when my coil pack went. It started running rough, seemed like it was going to stall, and didn't have much power. It was an instant change, and the engine light came on almost immediately. Luckily I was about a 1/4 mile from home, so I limped it home, put my spare coil pack in the next day, and then ordered a new one. I can't remember the code, but it wasn't super clear that it was a coil, but it did mention a misfire in one of the cylinders. After that experience my spare coil took up permanent residence in my trunk, as well as a small tool kit, so I could change it if I needed to on the road.
Hopefully it's that simple for you. I'm sure we'll know more if you post the code.
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 08-02-2017, 05:09 PM   #3
FreedomSoftware
2008 Astra XR
This has happened to me and it wasnt this. It was just the top of gas peddle wasnt working.
The code was P2138 "Throttle / Pedal Pos Sensor / Switch D / E Voltage Correlation" was what it read.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-1.25" Lowered
-JVC Head unit
-Dual 12" Subs
Old 08-02-2017, 06:00 PM   #4
TDA
TDA is on a distinguished road
2008 Astra XE
That sounds to me like it could be the sensor on the peddle itself going out.
Add to TDA's Reputation
Rate the quality of this post and help TDA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TDA is offline   Reply With Quote
Old 08-06-2017, 04:12 PM   #5
FreedomSoftware
2008 Astra XR
Thats what a mechanic I work with said. Thought it could be the throttle position sensor or the actual peddle going dead. Weird thing is I took note of the code and cleared it, and hasn't had the issue since. My peddle has always been a little finicky too
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-1.25" Lowered
-JVC Head unit
-Dual 12" Subs
Old 08-06-2017, 04:33 PM   #6
If your throttle (electric) and pedal (electronic) are part of a drive by wire system, you'll need to read about dbw systems and problems associated with them. The third and most important component of dbw is the ECM; pedal signals sent to the ECM, ECM commands the electric servo motor to move throttle. Throttle and pedal have dual position sensors for redundancy and safety to prevent engine runaway. Any error from one of four position sensors can trigger reduced power mode, more commonly known as limp home mode where the engine won't quit but allow just enough power to drive off a highway or street to a safe place for the emergency call.
Old 08-07-2017, 04:51 PM   #7
FreedomSoftware
2008 Astra XR
Well when this happened my car didn't go into limp mode, its like the top half of my peddle just wouldn't do anything. Only the bottom half would and it did have reduced power. But after a reset, it was fine and has been since then.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-1.25" Lowered
-JVC Head unit
-Dual 12" Subs
03 L300 no start unless the throttle motor/ throttle body unpluged Woody117 L-Series Tech 2 12-25-2012 06:33 PM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 04:20 PM
Throttle body fit sc2095 Mods and Performance 6 07-19-2004 06:08 PM
throttle body rascon11 Mods and Performance 0 02-09-2004 10:26 PM
Throttle body mod newt Mods and Performance 13 06-13-2002 05:46 PM
