Old 08-07-2017, 08:37 PM   #1
SweetT
SweetT has a spectacular aura aboutSweetT has a spectacular aura aboutSweetT has a spectacular aura about
Default Body Control Module/Power Booster
...and I'm back.
Okay, after reading threads, I've realized that my body control module is failing. Would that also cause my power brakes to go out? Saturday morning I lost my power brakes, I have to use my two little feet to brake hard enough to stop the car. Just wondering I'd the two are connected.
My car is a 2001 L300 3 Liter
Thanks!
Add to SweetT's Reputation
Rate the quality of this post and help SweetT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SweetT is offline   Reply With Quote
Old 08-07-2017, 08:59 PM   #2
pierrot
pierrot's Avatar
Default Re: Body Control Module/Power Booster
Originally Posted by SweetT View Post
...and I'm back.
Well...welcome back!!
...I've realized that my body control module is failing. Would that also cause my power brakes to go out? Saturday morning I lost my power brakes, I have to use my two little feet to brake hard enough to stop the car. Just wondering I'd the two are connected...
Answer: no. The power brake booster is not, nor are any of the basic operating components of your braking system, electrical. The booster operates with engine vacuum, the brake system is hydraulic and mechanical. If you have ABS then there are electrical components within the system, but they do not engage during otherwise normal operation. (This would not include emergency stops nor stops on wet/slick pavement.)
Your description of the manner in which you had to depress the brake pedal is consistent with a typical power brake booster failure. The failure results from a rupture of the vacuum diaphragm within the booster casing so that vacuum can no longer be held. You may notice poorer idling and engine performace as well. It is possible to have a complete loss of vacuum supplied to the booster. However, such a major loss of vacuum would also result in extremely poor engine idling and performance.
288,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 08-07-2017, 09:22 PM   #3
SweetT
Thank You!!!!!
Old 08-07-2017, 11:49 PM   #4
02 LW300
02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about
02 LW300's Avatar
2002 L-Series 2.2L Sedan
I had to replace the booster on my Lw300. I had a gradual loss of boost, they can also fail rapidly like yours.
2002 L200/5 loaded, loving my stick shift car finally on the road!
2002 L200 automatic, happy new owner
2002 LW300 sold.
Add to 02 LW300's Reputation
Body Control Module cnatsu1 L-Series Tech 0 11-12-2014 10:44 PM
Body control module?? 02L300sat L-Series Tech 52 06-19-2014 07:53 PM
Body Control Module Mark S. L-Series Tech 3 02-13-2009 08:52 AM
Body Control Module Rick M Vue General 1 01-08-2008 09:58 AM
engine control computer or power control module? Zekeboy S-Series Tech 10 12-20-2007 01:51 PM
