Old 08-02-2017, 08:52 AM   #1
Highmile
Highmile's Avatar
Default Highmile. End of the road?
Backstory, driving down my driveway looking at a HUGE buck with what is going to be a HUGE rack all in velvet still and as I imagining him hanging on my living room wall while enjoying a nice bbqd back strap when WHAM!!.... drove off the edge of the driveway and thru the ditch with the right front. Bounced HARD, really hard. Bounced us hard enough that it turned the windshield wipers on. I might have been going 10mph but even that is a stretch.
So, pulled the end out of the sway bar 3/16 or so and way out of alignment needless to say. Replaced the sway bar but wheel is still about 3/8 back from where it should be. Tried slotting the bolt holes in the top of the strut attach but things are still way out. They recommended a body shop saying it could be a LCA, strut, sub frame, etc etc etc.
The strange part is that after slotting the strut attach (which I actually did myself) the car drives straight with only the slightest of pull to the right.
So when time allows Ill pull it back in my shop and pull the wheel/brakes/etc and disassemble the pieces and parts. Hoping for something simple and bolt on.
Highmile
'95 SL1 635k and holding
Add to Highmile's Reputation
Old 08-02-2017, 09:11 AM   #2
Default Re: Highmile. End of the road?
Check the inner LCA attachment bracket as it is only spot welded to the cradle and the cradle may be buckled in that area. Also check the other side as the entire cradle can twist.
Old 08-02-2017, 09:42 AM   #3
BV22
2002 SC1
You can't give up yet - someone has to put a million miles on one of these cars. As OldNuc said, the LCA to cradle connection is a weak point.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 08-02-2017, 10:37 AM   #4
Dang
though I did come up with some different mental images, not involving deer, for this part
Old 08-02-2017, 12:36 PM   #5
Highmile
Highmile's Avatar
Originally Posted by alordofchaos View Post
Dang
Would have made a better story but sadly not the case.
Highmile
Old 08-02-2017, 04:53 PM   #6
jhonky
jhonky is on a distinguished road
Please figure out a cure and continue to drive your car
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 08-02-2017, 07:32 PM   #7
Saturn Night
www.car-part.com
Once you tear apart the car's suspension and get a proper diagnosis, look for some quality used parts to repair with.
Old 08-05-2017, 04:07 PM   #8
Highmile
Highmile's Avatar
Originally Posted by Saturn Night View Post
www.car-part.com
We have 4 you pull it type yards close to me. Parts are not an issue. Finding the right part to replace might be.
Highmile
Old 08-05-2017, 04:15 PM   #9
Highmile
Highmile's Avatar
Default Re: Highmile. End of the road? Updated
Well I had a lenghtly and enlightening afternoon with Mr Stanley. After checking several points on the subframe, checked for bent strut, etc, it was deemed that the replacement sway bar needed to come off for further analysis.
That analysis yielded some interesting information. It was bent and bent on the same side as my impact. So back to the salvage yard for a replacement.
In addition, the time with Mr Stanley showed the LCR attach points were good as well as all the other points we could measure. And there were a bunch of them. All points were measured from the cutout around the rear trailing arms when possible.
After being reassembled, Mr Stanley is showing the right wheel is now within a 1/16" of the left for fwd/aft and the camber and caster are well within adjustable limits.
We will know after another stop at the alignment shop.
As a shout out to the locally owned businesses.... I deal with Kennedy Tire in Festus Mo and they've had the car on the rack twice so far and have not charged me a dime. I think I'll have a couple of pizza's delivered once we get done.
Highmile
Old 08-05-2017, 04:45 PM   #10
Usually you have to actually hit the deer to bend the car. No points for just driving through the ditch.
Those small local shops are great.
Old 08-08-2017, 12:16 AM   #11
Saturn Night
Lolol. No points for the ditch......
Old 08-08-2017, 08:39 PM   #12
Jimmy123
Jimmy123 has a spectacular aura aboutJimmy123 has a spectacular aura aboutJimmy123 has a spectacular aura about
2002 SL
So is everything all good to go then Highmile?
Add to Jimmy123's Reputation
Rate the quality of this post and help Jimmy123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jimmy123 is offline   Reply With Quote
Old 08-09-2017, 07:39 AM   #13
Highmile
Highmile's Avatar
I'll know more after Thursday when we have a date with the alignment rack
Highmile
'95 SL1 636k and counting
Old 08-09-2017, 09:42 AM   #14
Waiex191
Waiex191's Avatar
I'm rooting for you!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 08-09-2017, 12:11 PM   #15
+1, fingers crossed!
Old 08-09-2017, 01:14 PM   #16
Highmile
Highmile's Avatar
I'm just guessing that everyone knows that Mr Stanley is a tape measure....
Highmile
Old 08-09-2017, 08:37 PM   #17
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Highmile
I didnt pick up on it until you mentioned it...
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-09-2017, 10:30 PM   #18
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Meanwhile 34 people go back and re-read his last post lol
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
Old 08-10-2017, 12:39 AM   #19
Mister_Cee
Mister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the rough
If 34 is correct, make that 35 now lol.
We are all gathered in the Saturn "surgical waiting room" anxiously awaiting the prognosis.
Add to Mister_Cee's Reputation
Rate the quality of this post and help Mister_Cee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mister_Cee is offline   Reply With Quote
Old 08-10-2017, 10:35 AM   #20
Highmile
Highmile's Avatar
Alignment appnt is at 4 local time and then I have some things to do after.
I'll update when I can.
I've been driving it as is and have to stay that it really doesn't feel too bad. No pulling at all but I can tell it is out.
Highmile
Highmile brakes Highmile S-Series Tech 6 11-22-2016 11:38 AM
end of the road? bone151 Astra General 11 01-08-2013 02:15 PM
End of the Road dmkinsey S-Series General 5 11-13-2009 03:30 PM
End of the Road 2KWhiteLS2inNY L-Series General 4 04-05-2008 12:33 PM
Has anyone seen a VUE on the road yet? Mark G Vue General 11 12-07-2001 09:11 AM
