Old 07-31-2017, 11:28 AM   #1
cjhsa
cjhsa is a jewel in the roughcjhsa is a jewel in the roughcjhsa is a jewel in the rough
Default Bad Front Axle Bearing (Not wheel bearing) ?
Thought I had a wheel bearing go bad again. Turns out its the bearing on the other end of the axle, where it mates to the (front differential?). Passenger side. Shop says this part is no longer made (no surprise there) and that it must a similar part must be special ordered. At least they will have it by Wednesday.
Anyone ever experienced this failure? It sounded exactly like a wheel bearing.
2007 VUE AWD V6 3.5L
Add to cjhsa's Reputation
Rate the quality of this post and help cjhsa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cjhsa is offline   Reply With Quote
Old 07-31-2017, 04:17 PM   #2
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Default Re: Bad Front Axle Bearing (Not wheel bearing) ?
Cj,
Look here. I did a full write up on how to rebuild/replace that bearing, with all parts numbers and tools needed.
http://www.saturnfans.com/forums/sho...d.php?t=204332
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
Add to lord_varon's Reputation
Rate the quality of this post and help lord_varon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lord_varon is offline   Reply With Quote
Old 07-31-2017, 05:17 PM   #3
cjhsa
Thanks John!
Old 08-01-2017, 02:17 PM   #4
Cavell
Cavell is a jewel in the roughCavell is a jewel in the roughCavell is a jewel in the rough
2004 VUE 3.5L
thats the axle intermediate shaft bearing assy? my new vue has a new pass side axle. and caliper. i didnt look to closely to see if the inner bearing assy had been touched. vue seems pretty smooth now.
Add to Cavell's Reputation
Old 08-02-2017, 06:41 AM   #5
lord_varon
lord_varon's Avatar
2008 VUE 3.6L
Cj,
I messaged you with my response already... Let us know how it turns out.
Cabell,
Those parts rarely go bad I have found... in fact, mine was not the issue at that point. So if you have new C/V axle and brakes, you should be fine. If it does go bad, my write up is the answer.
John
aka
Lord_Varon
Old 08-03-2017, 05:54 AM   #6
cjhsa
Their first attempt did not go well. They called me yesterday and said it was still making the noise, and they had ordered another part to try again today. This is crazy to me. I own a 33-year old BMW that I can still get any part for. Why would this part be unavailable when it's so critical?
Old 08-03-2017, 06:19 AM   #7
atikovi
It's hard to tell where a front wheel bearing noise is coming from. I too had replaced the passenger wheel bearing only to have the same noise as before. If you have AWD I would remove the driveshaft to make certain it's not drivetrain related. I checked the intermediate bearing by looking for slop or play and found nothing. Replaced the driver side bearing and the noise stopped.
Add to atikovi's Reputation
Old 08-03-2017, 06:58 AM   #8
cjhsa
I am very lucky to have a shop willing to try. I feel bad for them though. No parts available? What is this, a 1967 Studebaker?
Old 08-03-2017, 07:01 AM   #9
cjhsa
I asked about replacing the entire CV shaft assembly. They said there is nothing wrong with it. Yes to AWD. Are you saying disconnect the rear driveshaft?
Old 08-03-2017, 07:03 AM   #10
atikovi
Yes, to rule out the center support bearing.
Old 08-03-2017, 07:06 AM   #11
cjhsa
I've replaced that part before. It's very different (sound) when that bearing goes bad, but it could be possible.
Old 08-03-2017, 09:52 AM   #12
lord_varon
lord_varon's Avatar
2008 VUE 3.6L
Cj,
Did they actually find a matching intermediate shaft, or just swap out the bearing? If not the actual shaft, might want to take them my write up and have them follow the instructions. I will say though, my issue was actually not the intermediate shaft.... despite four or five different mechanics telling me that it was, My REAL issue was actually the center support bearing on the rear drive shaft, which all those same techs told me was just fine. So, try dropping the drive shaft and drive the vehicle without it for a while....you might be surprised.
John
aka
Lord_Varon
Old 08-03-2017, 10:49 AM   #13
cjhsa
They just swapped out the bearing. Twice. Waiting on take #2 results. If still bad, I will have them drop the rear driveshaft and take it for a spin. I owe them nothing but a diagnostic fee, if that, at this point.
Old 08-03-2017, 11:10 AM   #14
cjhsa
And btw, I swapped the center support bearing not once but twice. The second time I had the driveshaft rebalanced as well. Unfortunately that shop no longer exists, so I'm out of luck with any possible warranty.
Old 08-03-2017, 04:15 PM   #15
cjhsa
So, they are now saying the bearing the took off is fine, and feel the issue is in the transmission. They also said the carrier bearing is fine as are the wheel bearings. So, is this car headed to the scrapyard?
Old 08-04-2017, 01:51 PM   #16
cjhsa
Too quiet in here!
Old 08-04-2017, 03:20 PM   #17
atikovi
Drive it til it blows.
Old 08-05-2017, 03:52 PM   #18
cjhsa
Lol! Was thinking that. Not really but a little.
Old 08-07-2017, 10:18 AM   #19
cjhsa
Outside of this the vehicle is in very good shape. Would folks here consider fixing it? And up to what cost? I'm asking what you would do in my shoes.
Old 08-08-2017, 07:56 PM   #20
cjhsa
Turned out to be the DRIVERS side front wheel bearing. smh...
Wheel bearing or axle) russellc S-Series Tech 2 02-23-2016 12:24 PM
Front end noise, wheel bearing or cv axle?? hatrik8 S-Series Tech 13 03-03-2012 04:18 PM
wheel bearing or axle? or neither? Squishyzach S-Series Tech 0 08-28-2009 11:54 AM
Wheel bearing or cv-axle? Geronimo S-Series Tech 8 07-27-2007 01:58 AM
Axle half shaft or wheel bearing?! Partymmudasti S-Series Tech 4 10-24-2005 09:19 PM
